Used Delta 22-580
Forum topic by TheGreatJon posted 01-19-2015 02:10 PM 1640 views 0 times favorited 6 replies Add to Favorites Watch
View TheGreatJon's profile
TheGreatJon
337 posts in 1229 days
01-19-2015 02:10 PM
Topic tags/keywords: planer bearing
I’m looking at buying a Delta 22-580 planer from a classified ad. The owner says that it needs a new bearing, and he is asking $65 for it. To me, a decent planer at $65 is something to leap at. However, I’ve never tried to replace a bearing on a newer benchtop planer. Has anyone done it with this model (or similar)?
-- This is not the signature line you are looking for.
View johnstoneb's profile
johnstoneb
2914 posts in 2168 days
#1 posted 01-19-2015 02:21 PM
http://www.ereplacementparts.com/delta-22580-type-planer-parts-c-3275_3571_3582.html?q=22-580
I think I would try to get it for less. I don’t think it’s to hard to change the bearings on the head. Right now the planer is junk and it will be until the bearings are replaced.
The planer is a reliable lunchbox planer when it is running. I had an earlier model. It worked well. I replaced it with a DW735.
The above website will give you an idea of what parts are still available and cost.
-- Bruce, Boise, ID
View scottstef's profile
scottstef
18 posts in 1276 days
#2 posted 01-19-2015 11:42 PM
9i have this planer and love it. i just replaced the switch after 10 years. it took me 3 days to get a replacement switch. it is a great planer and can have minimum snipe if you set up properly.
View ElChe's profile
ElChe
630 posts in 1331 days
#3 posted 01-20-2015 01:25 AM
Make sure you can still get parts. I have the 22-560 and it is obsolete. Well not to me but you can’t get parts for it. I keep jerry rigging it and so far so good.
View watermark's profile
watermark
483 posts in 1938 days
#4 posted 01-20-2015 07:22 AM
I have the same planer and recently got it running right after replacing blades, locking bar and the in feed roller. Parts are not always available but I have had luck with acetoolrepair.com which apperently has joined forces with toolpartsdirect.com since my last order … no idea if that changes anything.
Like johnstoneb said I would try and get it for less if not free. With a bad bearing and who knows what else … it’s not worth much.
-- "He who has no dog, hunts with a cat" Portuguese proverb
TheGreatJon
#5 posted 01-23-2015 12:56 PM
Thanks for all of the input guys. I really appreciate it. I sent the guy a follow-up email, but I’ve yet to hear back from him. We will see.
View Ghidrah's profile
Ghidrah
667 posts in 1217 days
#6 posted 01-23-2015 11:31 PM
I’ve had a 540 since 91, still use it in the shop for small projects and or when I don’t want to change out the knives on the JPM13.
-- I meant to do that!
