Cabinet Door Hinge Templates
Forum topic by skydiver posted 01-18-2015 08:39 PM 1448 views 0 times favorited 17 replies Add to Favorites Watch
View skydiver's profile
skydiver
15 posts in 2109 days
01-18-2015 08:39 PM
Topic tags/keywords: templates hinges cabinet doors
I am at the final stages of my first form scratch wood project. I have built 18 replacement shaker style cabint doors out of maple and mdf. These doors have a 3/8” inset and a 3/8” overhang of the cabinet opening with a face frame edge mounting method. These are replacements for the original doors that had a 1/2” overlay/3/8” inset and brass hinges that we couldn’t find stainless replacements for.
Here is the hinge we are using: https://img.goingm.com/Images%5CAmerock/amerock_pn_BP7565G10.jpg
I need to find/build a template to mount the hinges to the cabinet doors and to drill the pilot holes for the hinge into the face frame to ensure all the cabinets are square and level.
All i can find online are template system for european cup hinges. Does anyone have any suggestions where or how to create a solid template that will work for this?
17 replies so far
View Nubsnstubs's profile
Nubsnstubs
1245 posts in 1634 days
#1 posted 01-18-2015 08:45 PM
Try Amerock. I have one for surface mount hinges with that pattern. ......... Jerry (in Tucson)
View skatefriday's profile
skatefriday
413 posts in 1386 days
#2 posted 01-18-2015 08:47 PM
I know this is not the answer you are looking for, but I just finished
installing doors into my first cabinet. I used the blum clip top hinges
and they are fantastic. Used a jig on a drill press to bore out the cups,
mounted the plates to the cabinet, clicked the doors on, a couple
quick adjustments on the cam and it looked like a professional did it.
I can’t recommend these hinges highly enough. And picked them up
for about $4.00 per hinge from a cabinet maker’s supply place.
View verdesardog's profile
verdesardog
154 posts in 2515 days
#3 posted 01-18-2015 08:57 PM
Make your own jig!
-- .. heyoka ..
skydiver
#4 posted 01-28-2015 04:37 PM
Thanks for the feedback. I am going to opt for making my own jig. I am going to need to create two jigs:
One for the faceframe edges (a single jig for the top & bottom hinge locations should)
One/two for the cabinets faces I need to make this so they are good for both left and right cabinets (Remember i have a 3/8” rabbet for the cabinets).
Does anyone have a how guide or suggestions on materials/design? I would like to create something that would actually be re-usable with the same hinges. I am considering remaking the bottom cabinets with bead-board MDF panels if we decide the flat MDF panels are too plain.
skydiver
#5 posted 01-28-2015 06:09 PM
I was thinking of building it out of sheet metal kind of like this:
but I don’t have a bending brake.
View scvwood27's profile
scvwood27
117 posts in 1855 days
#6 posted 01-28-2015 06:20 PM
Totally off topic, but why did you use Maple if you plan on painting the doors? You are painting them right, considering the MDF panels? Why spend the extra money on maple instead of poplar or some other less expensive wood?
skydiver
#7 posted 01-28-2015 07:17 PM
I was going to use poplar for the rails and stiles with MDF inserts but on the first test cabinet door I made, it seems to get dinged very easily. s4s Maple was $1.42 BF vs. $1.15 BF for poplar so I splurged. It upped the cost about $45 for the whole project and made my wife happy.
scvwood27
#8 posted 01-28-2015 08:42 PM
Nice. Maple is 3.99 a bf around here. Poplar isn’t much cheaper. Dang!
View KDO's profile
KDO
154 posts in 2673 days
#9 posted 01-28-2015 08:59 PM
Did you try contacting Amerock like Jerry suggested, since those are Amerock hinges?
The few times I have done that, the hinge company had a template.
-- Christian, Husband, Grandpa, Salesman, amateur Woodworker.
skydiver
#10 posted 01-28-2015 10:08 PM
Yes I did call and after ten minutes of taking to the guy explaining what a jig was used for, he told be to go to home depot…
skydiver
#11 posted 01-08-2016 06:17 PM
So it has been awhile since I updated this post. The project is 95% complete with a few hiccups along the way including losing 1/2” on my middle finger and 1/3” on my ring finger of my right hand. I wrote a blog post on my google plus page along with photos CAUTION GRAPHIC PHOTOS ON THIS POST: https://plus.google.com/109645038641482544273/posts/dpk8pb9aVed
skydiver
#12 posted 01-08-2016 06:22 PM
I would be joyful to discuss a better router table lift system than what I used to build the cabinets. I am kind of gun shy to finish building the remaining three cabinets until I get a batter router table solution.
View cabmaker's profile
cabmaker
1694 posts in 2713 days
#13 posted 01-08-2016 06:24 PM
Industry standard for spacing on the hinge you show is the width of the hinge plate itself.
skydiver
#14 posted 01-08-2016 07:28 PM
I ended up buying a cheap metal bending break from Harbor Freight and built this:
I first drilled the location for the left handed hinges into the template backed by a scrap piece of rail stock. I then flipped the stock over, flipped the template over and drilled from the wood through the template for the other side.
I then did the same for the pulls:
I think they came out pretty well:
skydiver
#15 posted 01-08-2016 07:29 PM
Sorry for the huge photos, trying to figure out Photobucket…
