Old back saw
« back to Hand Tools forum
Forum topic by oltexasboy1 posted 01-18-2015 05:53 PM 967 views 0 times favorited 6 replies Add to Favorites Watch
View oltexasboy1's profile
oltexasboy1
250 posts in 1822 days
01-18-2015 05:53 PM
Topic tags/keywords: handsaw backsaw splitnuts saw restoration question refurbishing
Does anyone here have any experience with removing split nuts from an old saw? I have a 24” back saw I bought for cutting tenons that I am going to restore and resharpen but I have never tried to remove a split nut from a saw handle before and I don’t want to ruin the thing before I get a chance to use it. Anybody have any ideas, I figure that I have enough old screwdrivers I could sacrifice one to the cause and just grind a slot in the center of the blade so as to miss the screw end and still be able to loosen the nut. Again, any ideas?
-- "The pursuit of perfection often yields excellence"
View Grumpymike's profile
Grumpymike
2289 posts in 2433 days
#1 posted 01-18-2015 06:20 PM
The proper tool is a spanner (wrench), but to find one the right size is a challenge. Most of us do like you described, and make one out of flat stock or an old sacrificial tool.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
oltexasboy1
#2 posted 01-18-2015 06:49 PM
I literally have a “pile” of old screwdrivers and I think that’s the route o go.
View Tim's profile
Tim
3812 posts in 2079 days
#3 posted 01-18-2015 06:59 PM
If you don’t have a screwdriver wide enough you can make one out of a spade bit too. You want to grind the shape until it fits perfectly.
Another idea I think is from Andy on the saw thread but I’m just trying to remember the best I can. Any mistakes are my own. The idea is to take a piece of scrap wood and drill a hole just a hair larger than the size of the nut and clamp that to the handle around the nut you are removing. That helps reduce the blowout of the wood as the nut comes out. On the other side you may need to clamp a piece of rubber against the smooth side to stabilize it and keep it from spinning.
The basic idea is to ease them out. Unscrew a bit, then back off, then try a little bit more, then back off, etc. They break sometimes even if you’re careful, but being careful helps.
Maybe one of the guys with more experience will stop by here too.
oltexasboy1
#4 posted 01-19-2015 02:25 PM
Thanks guys I’ll keep you updated .
View Greg In Maryland's profile
Greg In Maryland
553 posts in 3116 days
#5 posted 01-19-2015 06:30 PM
Blackburn tools has them for sale: http://www.blackburntools.com/new-tools/new-saws-and-related/saw-nut-spanner/index.html
My experience is that the slots in split nuts are much too narrrow to repurpose a screwdriver for. It was easier to buy the right tool than it was to fiddle with grinding a surplus screwdriver.
Greg
View waho6o9's profile
waho6o9
8360 posts in 2694 days
#6 posted 01-19-2015 06:33 PM
One can be made out of an old spade bit.
