NOT A REVIEW
Forum topic by Garbanzolasvegas posted 01-18-2015 03:59 PM 1101 views 1 time favorited 16 replies Add to Favorites Watch
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1222 days
01-18-2015 03:59 PM
One of my girlfriends got me a LOWES Porter Cable floor drill press which I have had my doubts about, BUT its turned out to be quite the nice drill press.
BUT I am not sure if the rotation of the quill and chuck is TRUE?
I have had mandrill bits in it and some seem to not spin true.. Seems to wobble just the finest bit.
BUT this may be from using old bent bits.
How can I do an honest test to check this out
-- If you don't Play, you can't win
16 replies so far
View Yonak's profile
Yonak
986 posts in 1516 days
#1 posted 01-18-2015 04:14 PM
All these CAPS remind me of another poster.
View DIYaholic's profile
DIYaholic
19620 posts in 2670 days
#2 posted 01-18-2015 04:21 PM
You need to determine the runout.
With a setup like this….
You want to check with a known straight rod (or bit), as close (high) to the chuck as possible.
You also want to check the chuck itself and the quil/spindle.
Garbanzolasvegas
#3 posted 01-18-2015 04:23 PM
I have a MIC that I use on my table saw for its run-out. Guess I need that nifty magnet contraption… Where did you get yours and what is the proper name for it?
View ElChe's profile
ElChe
630 posts in 1331 days
#4 posted 01-18-2015 04:30 PM
Its proper name is “Bob”. ;). It is a dial indicator magnetic base. Harbor Fright sells one. Starrett sells one for an astronomical price. I’m thinking of getting one. Make sure your chuck spindle is firmly seated in the Morse taper. I give mine a good whack with a mallet on a scrap of wood once in a long while if it starts misbehaving.
DIYaholic
#5 posted 01-18-2015 04:31 PM
I got my magnetic base from Harbor Freight….
(BTW: That is an image I found online.)
You could do a shop made hold down of some sort….
Just a lot easier setup with the magnetic base.
View Tooch's profile
Tooch
1747 posts in 1871 days
#6 posted 01-18-2015 04:32 PM
I believe its a Dial Indicator. not sure where to purchase one but a quick google search yielded these results:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=dial+indicators&tbm=shop
-- "Well, the world needs ditch-diggers too..." - Judge Smails
View gtbuzz's profile
gtbuzz
427 posts in 2436 days
#7 posted 01-18-2015 04:59 PM
I bought my dial indicator + base off of ebay. If I recall it was something like $30 shipped on the slow boat from China. Works great though. When I check the runout on mine (really only checked it once and have just been fat dumb and happy since then), I checked against a punch transfer tool in the chuck. IIRC, I had +/- 3 thou or so. Some of the cheap-o brad point drill bits I’ve got are way sloppier than that so I’m very happy with that number.
But enough about your drill press. Let’s talk about your multiple girlfriends… do they all get you tools? If so, I think I’m living my life wrong :)
Garbanzolasvegas
#8 posted 01-18-2015 05:51 PM
I bought my dial indicator + base off of ebay. If I recall it was something like $30 shipped on the slow boat from China. Works great though. When I check the runout on mine (really only checked it once and have just been fat dumb and happy since then), I checked against a punch transfer tool in the chuck. IIRC, I had +/- 3 thou or so. Some of the cheap-o brad point drill bits I ve got are way sloppier than that so I m very happy with that number.
But enough about your drill press. Let s talk about your multiple girlfriends… do they all get you tools? If so, I think I m living my life wrong :)
No only my primary GF gets me tools. The secondary and throe string don’t get me anything. WELL Maybe they DO get me a few things.. Wink wink!
Hard part is Scheduling.
- gtbuzz
View oltexasboy1's profile
oltexasboy1
250 posts in 1699 days
#9 posted 01-18-2015 06:05 PM
Central also makes a good dial indicator that is more reasonably priced. I have a Central that I have used for years and it works very well and was accurate enough for me to use it to build engines and all kinds of other stuff for years. I use a transfer punch or you can use a router centering pin, they are very straight and will give you a clear indication as to whether or not it is the bit or the drill press. For me .002-.005 (+ -) is plenty good your not using it as a milling machine it’s just a drill press.
-- "The pursuit of perfection often yields excellence"
View wncguy's profile
wncguy
392 posts in 2307 days
#10 posted 01-18-2015 07:16 PM
“One of my girlfriends got me…”
So how many GF’s do you have & what did the rest get you?
-- Any man can be a father, but it takes someone special to be a Dad
Garbanzolasvegas
#11 posted 01-18-2015 07:54 PM
So how many GF s do you have & what did the rest get you?
- wncguy
CLASSIFIED!
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2304 days
#12 posted 01-18-2015 08:35 PM
- wncguy
CLASSIFIED!
- Garbanzolasvegas
Get your girl friends to buy you a jointer and planer before you re-arrange you shop. It would save you time latter.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3226 days
#13 posted 01-18-2015 08:57 PM
I got the base and dial indicator at HF. $12-14 each. Measures to .001.
Find the high side and tap it with a hammer, recheck, repeat.
View CharlieK's profile
CharlieK
555 posts in 3788 days
#14 posted 01-19-2015 03:32 AM
- wncguy
Yep! That’s the first thing that jumped out at me, too!
“ONE” of your girlfriends?
Whadda guy!
Whadda lucky guy!
-- Adjustable Height Workbench Plans http://www.Jack-Bench.com
Garbanzolasvegas
#15 posted 01-19-2015 03:53 AM
- wncguy
Yep! That s the first thing that jumped out at me, too!
Whadda guy!
Whadda lucky guy!
- CharlieK
Its a curse really!
