Contact cement smells!!
Forum topic by zacgooch posted 01-18-2015 03:08 PM 2980 views 0 times favorited 5 replies Add to Favorites Watch
View zacgooch's profile
zacgooch
6 posts in 1337 days
01-18-2015 03:08 PM
Topic tags/keywords: contact cement fumes smells
I built a cabinet for my car and I used dap weld wood contact cement on part of it. And three days later the fumes are so bad you can barely be in the car. How long does it take before the fumes dissipate?
5 replies so far
View mahdee's profile
mahdee
3919 posts in 1824 days
#1 posted 01-18-2015 03:37 PM
It should’t smell. Did you make sure both surfaces were tacky dry before assembly?
-- earthartandfoods.com
117160 posts in 3634 days
#2 posted 01-18-2015 03:43 PM
In a closed space it can take some time if you can leave the windows open that will help,I hope you noted the fumes are highly flammable
View Crank50's profile
Crank50
173 posts in 1633 days
#3 posted 01-18-2015 04:32 PM
Biggest mistake I see folks make with contact cement is failing to let it almost dry before bringing the items to be glued together.
View ElChe's profile
ElChe
630 posts in 1393 days
#4 posted 01-18-2015 04:46 PM
It takes time ventilation and maybe hot weather. A couple of days in the sun at say 70 degrees and it will cure.
View gfadvm's profile
gfadvm
14940 posts in 2747 days
#5 posted 01-19-2015 01:15 AM
The water based stuff is odorless (but too late for this advice!). Time and ventilation are the answer to your current smell.
