router question
Forum topic by woodworkingdrew posted 01-18-2015 04:34 AM 1153 views 0 times favorited 11 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1785 days
01-18-2015 04:34 AM
I was wondering for long boards i.e. 8-12 ft long that need edges routed, is it better to run the long boards on a router table or just run the router in a base down the length of the board. Thanks
-- Andrew, California
11 replies so far
View TheFridge's profile
TheFridge
10504 posts in 1662 days
#1 posted 01-18-2015 04:38 AM
Depends on the bit for me. If it has a bearing and doesn’t require a stop or fence I’ll use the handheld.
View ChuckC's profile
ChuckC
843 posts in 3111 days
#2 posted 01-18-2015 04:44 AM
For a board that long I would go handheld if I could.
View distrbd's profile
distrbd
2252 posts in 2622 days
#3 posted 01-18-2015 04:46 AM
I would also go with handheld,it’s much easier.
-- Ken from Ontario, Canada
View jmartel's profile
jmartel
8199 posts in 2326 days
#4 posted 01-18-2015 04:56 AM
The larger the pieces are, the easier it is to bring the tool to the workpiece rather than the workpiece to the tool.
View klassenl's profile
klassenl
190 posts in 2835 days
#5 posted 01-18-2015 02:37 PM
I did a 13 foot flooring transition on the router table once. Feather boards kept everything straight.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View ChefHDAN's profile
ChefHDAN
1140 posts in 3025 days
#6 posted 01-18-2015 02:43 PM
All depends on the cut your machine & your set up. I get better dust extraction at the table so if it’s just a matter of moving stands to support in/out feed, I’ll often do that.
View verdesardog's profile
verdesardog
171 posts in 2787 days
#7 posted 01-18-2015 03:34 PM
I use a small handheld trim router for all edging
-- .. heyoka ..
117276 posts in 3753 days
#8 posted 01-18-2015 03:51 PM
Depends on the size of your router table the type of router you have and your experience using a router,but generally on longer pieces I agree with using a hand help router for edge routing wood that long.
HillbillyShooter
5811 posts in 2468 days
#9 posted 01-18-2015 03:53 PM
Agee w/ a1Jim.
View Picklehead's profile
Picklehead
1048 posts in 2105 days
#10 posted 01-18-2015 05:38 PM
The main problem with a router table and a long board is that any crook in the board will change the profile of the cut as the fence pushes the board away from the bit, whereas a shorter edge guide on the router will not, and a bearing-quided bit will follow the edge exactly.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
woodworkingdrew
#11 posted 01-18-2015 08:25 PM
Thanks for all the responses. That’s exactly the problem I am facing. I am getting a lot of board movement and an uneven profile. I will use handheld from now on with long boards.
