What's wrong with my saw?
Forum topic by SirIrb posted 01-18-2015 03:25 AM 873 views 0 times favorited 10 replies Add to Favorites Watch
View SirIrb's profile
SirIrb
1239 posts in 1230 days
01-18-2015 03:25 AM
I have a mid to late 70s craftsman (which will be replaced soon) “cabinet” style table saw. If the blade is up and I tighten the belt, great. If I lower the blade the belt gets loose proportionally to the amount it dropped. This seems to be kinda new. I have totally cleaned and lubed it to no avail. Anyone else have this issue? I am thinking about loosening the motor screw and place compression springs behind the motor. Got a better fix?
Thanks.
10 replies so far
18200 posts in 1856 days
#1 posted 01-18-2015 03:32 AM
Is the belt worn to the point where it does not fit tightly in the pulleys and is now effectively longer?
SirIrb
#2 posted 01-18-2015 03:34 AM
It was. Then I got a new one. Still have the same problem.
View DIYaholic's profile (online now)
DIYaholic
19620 posts in 2675 days
#3 posted 01-18-2015 03:46 AM
If you could post the model number and/or pictures….
It would help people to diagnose the problem.
SirIrb
#4 posted 01-18-2015 03:49 AM
I’ll do that in the morning. Thanks. It has to be a simple problem. Also it is quite stiff when I try to raise/lower or angle the blade, if that helps.
View MrUnix's profile
MrUnix
6715 posts in 2198 days
#5 posted 01-18-2015 03:53 AM
When was the last time you got up under the hood and gave things a good cleaning/lube? Sounds like it just needs a little routine maintenance.
SirIrb
#6 posted 01-18-2015 04:05 AM
I lubed it today. Made sure to really get the lead screws. Still, it’s like the motor should translate with the movement of the blade but it doesnt. Mechanically that doesn’t make sense since the motor is stationary. Should I tighten the belt with the blade dropped and let it get tighter as it raises? That, to me, could stall the motor. Can’t wait to get that 1960’s unisaw in. I’ll use this craftsman as an anchor for the s.s. regret.
View David_H's profile
David_H
90 posts in 1318 days
#7 posted 01-18-2015 04:08 AM
To be clear because I was not aware that craftsman put out a cabinet style saw in the mid to late 70’s, does the motor hang out of the back like a contractor saw? If so then I would assume that the screw that the motor bracket pivots on is too tight and your motor is not raising and lowering with your blade? The motors weight is what provides tension to the belt, it will not stall out. Of course assuming your motor hangs out the back.
SirIrb
#8 posted 01-18-2015 04:14 AM
I called it cabinet only because it is enclosed. Most definitely not a cabine sawt. So I will assume I tightened the screw too much. Assume that the motor provides the resistance by its own weight. (Quietly wish I could delete this thread.) And go slap a wrench on that saw. And you, good sir, are a gent for putting up with morons. My excuse…I only worked on old powermatic saws and never had to touch a belt on one.
[He quietly exits stage left].
David_H
#9 posted 01-18-2015 04:20 AM
Lol, don’t worry about it, I made the same mistake once upon a time after purchasing my new to me craftsman contractor saw, I spent a good ten minutes wondering what was wrong with this hung of junk saw until it dawned on me… So yeah its a mistake you don’t make twice, and congrats on your impending cabinet saw.
DIYaholic
#10 posted 01-18-2015 05:29 AM
Sounds like you’ve got it sorted out….
