Tablesaw blade guard
Forum topic by bruc101 posted 01-18-2015 01:41 AM 1893 views 0 times favorited 6 replies Add to Favorites Watch
View bruc101's profile
bruc101
1197 posts in 3448 days
01-18-2015 01:41 AM
We had to move a Grizz 3 hp tablesaw to an area in the shop where the over arm blade guard won’t fit. Anyone got an suggestions on a guard that will work, with splitter, that we can mount to the saw?
Thanks in advance.
-- Bruce Free Plans http://plans.sawmillvalley.org
View mrg's profile
mrg
804 posts in 2906 days
#1 posted 01-18-2015 01:58 AM
How about ordering them from Grizzly if still available?
-- mrg
4881 posts in 2400 days
#2 posted 01-18-2015 12:31 PM
Shark Guard, the downside in your case may be the lead time.
View knotscott's profile
knotscott
7874 posts in 3282 days
#3 posted 01-18-2015 01:20 PM
Which of the Grizzly 3hp saws do you have? If one of the older G1023”S” series, then the stock guard, BORK, or Sharkguard should work.
The BORK is a retrofit riving knife that travels with the blade. It’s not quite as robust as the Sharkguard, but has the advantages of a riving knife vs a splitter.
View ElChe's profile
ElChe
630 posts in 1243 days
#4 posted 01-18-2015 07:01 PM
Interesting. How easy are the Bork or the Shark to remove for non through cuts? I took off the blade guard on my unisaw years ago and use an microjig splitter but I would like a blade guard. The stock Unisaw blade guard was dangerous and would bind the wood at the splitter.
View Loren's profile
9963 posts in 3554 days
#5 posted 01-18-2015 07:11 PM
You might consider the Brett guard. You can get them
on ebay reasonably.
knotscott
#6 posted 01-18-2015 11:49 PM
For non-through cuts you’d have to remove the Shark guard and splitter. The BORK can be set so that you just remove the guard easily and leave the riving knife in place….or you can remove the knife too very easily. Neither is very difficult.
