King CH900C or Harbor Freight 34706 parts
« back to Woodturning forum
Forum topic by JADobson posted 01-17-2015 09:25 PM 3414 views 0 times favorited 11 replies Add to Favorites Watch
View JADobson's profile
JADobson
1015 posts in 2079 days
01-17-2015 09:25 PM
Topic tags/keywords: reeves drive lathe king harbor freight
Hi everyone,
I was having some trouble with the speed adjustment on my lathe (mine is the King model, but I believe it is exactly the same as the HF model) and when I was fiddling with it today the reeves drive fell apart on me. Does anyone know where one could get parts for this machine. I’ve looked at the King manual for the lathe (http://www.manualslib.com/manual/87313/King-Canada-Ch-900c.html) and the parts there seem pretty pricy. I’d like to replace the bearings while I’m at it but also can’t figure out how to remove the key from the shaft (#32 on the parts list). So I haven’t been able to get to the bearings to see what size I need. Any help with this would be appreciated. Thanks.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany
11 replies so far
View Wildwood's profile
Wildwood
2300 posts in 2103 days
#1 posted 01-17-2015 09:57 PM
Here is the HF manual. looks like their lathe uses 6205ZZ (shielded bearings) available anywhere for less than $20 each.
If need reeves drive components would have to call toll free number in HF manual and get a quote.
http://manuals.harborfreight.com/manuals/34000-34999/34706.pdf
I would print off page 15 of HF manual for disassembly procedures.
Only experience with Asian reeves drive was with a Delta 46-700. Ended up removeing plastic cover, & reeves drive pulley assembly. Putting a 4-slot pulley on lathe spindle and lathe motor. Motor was bolted to new bracket that swung in and out bolted to the late bed. You would have to modify or completely remove sheet metal cover to do something like I did. Headstock did not rotate after that modification.
-- Bill
View Mike82352's profile
Mike82352
17 posts in 1218 days
#2 posted 01-20-2015 01:09 AM
I have the part that goes on the motor, I burnt up my motor so I added a 1 1/2hp 3 phase motor and VFD to my HF lathe. You can have it if you can use it.
-- Want....... what you already have......
JADobson
#3 posted 01-20-2015 01:14 AM
Mike, PM sent.
Mike82352
#4 posted 01-20-2015 02:16 AM
Is this the parts you need? Just got them off the motor.
JADobson
#5 posted 01-20-2015 02:23 AM
That’s it.
View waho6o9's profile
waho6o9
8168 posts in 2545 days
#6 posted 01-20-2015 02:26 AM
Mike82352 for the win!
2 cool
JADobson
#7 posted 01-20-2015 02:32 AM
2 cool
- waho6o9
I’ll say.
Mike82352
#8 posted 01-20-2015 02:38 AM
Glad to help…....I’m upgrading my shop and was just going to pitch the old motor and pulley. Glad someone can use the parts.
Mike82352
#9 posted 01-21-2015 04:00 PM
The pulley is on it’s way, hope it works out…
View Jim Jakosh's profile
Jim Jakosh
20314 posts in 3074 days
#10 posted 01-04-2016 08:34 PM
Anyone else have any of these??. The outer pulleys on the motor and the spindle just broke and threw the belt on mine and I cannot get to the place to put in the model number on Harbor Freight Parts.com.
I have their number 1-800-444-3353 and they put me on hold forever.
Jim
Mike82352
#11 posted 01-04-2016 09:31 PM
Jim,
I’m still using the reeves drive on the lathe.
