Best method for satin finish?
Forum topic by Marshall posted 01-17-2015 08:37 PM 964 views 0 times favorited 4 replies Add to Favorites Watch
View Marshall's profile
Marshall
151 posts in 2021 days
01-17-2015 08:37 PM
Hello All,
I’m currently finishing a walnut kitchen table. I have three coats of gloss Arm R Seal on it now. Usually, I use satin Arm R Seal for my final coat. I did that on the bottom of the table, but it seemed to cloud the grain. I liked it better when it was gloss, before I did the satin final coat.
I havent really noticed that before, but I usually work with stained oak, so maybe the gnarly grain of the walnut top makes me notice it more?
I’m reasonably certain I dont want to leave it super glossy like it is now. My question is, do you think I’d get better results by rubbing the gloss finish to a more satin sheen rather than top coating it with satin arm r seal?
Thanks!
-- Marshall - http://mcomisar.tumblr.com
View pjones46's profile
pjones46
1001 posts in 2609 days
#1 posted 01-17-2015 09:07 PM
Satin coatings have a filler in them to yeild the satin appearance. These fillers also impact the clarity of the coating/finish.
IMHO, rubbing the gloss finish to a more satin sheen rather than top coating it with satin arm r seal is the way to go. You can always recoat if it does not come up to your expected standards.
-- Respectfully, Paul
Marshall
#2 posted 01-17-2015 10:01 PM
Thanks. The rubbing process creates scratches that cause the more satin sheen correct? So if i were to mess it up, If I recoat with gloss after rubbing out, does it restore the glossy sheen?
pjones46
#3 posted 01-17-2015 10:18 PM
Yes. Try it on a scrap sample to prove it to yourself.
pjones46
#4 posted 01-17-2015 11:40 PM
Another hint is to use a finishing wax like Staples Crystal Clear after you rub out the gloss. It will giver the end result of a deep mellow glow as best as I can discribe it.
