Best way to make inlay banding
Forum topic by TheCaver posted 244 days ago 321 views 0 times favorited 6 replies Add to Favorites Watch
View TheCaver's profile
TheCaver
292 posts in 735 days
244 days ago
Anyone have ideas on the best way to make this:
http://inlays.com/item.asp?PID=1014&cID=28
Thanks!
JC
-- Somewhere, something incredible is waiting to be known. -Carl Sagan
7654 posts in 1114 days
244 days ago
With a computer and a credit card. :-)
View marcb's profile
marcb
704 posts in 569 days
244 days ago
You would probably have to glue it up in a long blank then slice it off with a bandsaw.
Sounds like a LOT more trouble than it is worth.
TopamaxSurvivor
3039 posts in 572 days
244 days ago
Charlie’s way is the fasteest and easiest:-))
You need to make lots of little strips, blocks and veeners; glue them up in the pattern and cut them off with a fine tooth saw. Inlay them a bit proud so you can sand them off flush. Don’t sand too agressively or you will build up to much heat on the banding.
Inlay with a bit of a bias to the bottom of the track will allow you to achieve a “no gap” inlay line.
Craftsman on the lake
818 posts in 334 days
244 days ago
Glue up strips as a slab then slice off sections afterwards. This similar method is used to make the small blocks that are use to make the rosettes around classical guitar sound holes.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
20707 posts in 718 days
244 days ago
Here is a video by Keith Cruickshank that may help.
View ryno's profile
ryno
86 posts in 560 days
244 days ago
here is a good site to check out. on this page watch the 2nd video and it relates specifically to your question. its just a matter of figuring out your pattern and angles.
http://woodtreks.com/category/techniques/inlay-marquetry/
-- It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.
