Forum topic by Eric | posted 01-17-2015 06:09 PM | 859 views | 0 times favorited | 5 replies | ![]() |
Anyone ever put a top coat of rubbing poly over lacquer? You get the quick finish build up with lacquer and the control of rubber poly on the top-most coat. -- Eric |
5 replies so far
#1 posted 01-17-2015 07:39 PM |
I’ll bite…. I’m not sure why you would want to. I can spray or brush lacquer about as thin as watered down water and rub poly doesn’t add much to that. Lacquer layers will melt into the layer before to make a stronger bond. Poly on top of lacquer will not soak in or blend with the lacquer so you will end up with two discrete layers of finish. It wouldn’t be so bad, but no finish that I have found is impervious to water infitration. Some is just easier to repair than others. I dunno if that helped or not, I just wouldn’t do it. -- Improvise.... Adapt...... Overcome! |
#2 posted 01-17-2015 07:57 PM |
I don’t see an advantage to including poly in the finishing schedule. Spraying lacquer offers good control and will build a nice finish in two coats. Wet sand the top coat with a 1500 grit soft sponge. On medium sized projects such as desks and coffee tables, wet sanding takes about 15 minutes. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#3 posted 01-17-2015 08:09 PM |
Never heard the term “rubbing poly” what is that? -- Alaskan's for Global warming! |
#4 posted 01-18-2015 04:50 AM |
Maybe he’s talking wipe on poly and rubbing the finish out? I would stick with the Solvent-based Lacquer. Sounds like he is trying to obtain a satin finish? -- Respectfully, Paul |
#5 posted 01-19-2015 09:36 PM |
By rubbing poly I mean wipe-on poly. sorry. The idea was to get a fast build with the faster drying lacquer. The lacquer I was spraying wasn’t laying down well so I did a sample topcoat of wipe on poly to get the smooth control I was hoping for. To solve my problem I thinned the lacquer and sprayed a fresh fully wet coat. That seemed to fix it! Finishing in the dead of winter is terrible. Wish I can have warmer temps and the garage door wide open! -- Eric |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6695 |
28062 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
