Loose handle on tang chisel
« back to Hand Tools forum
Forum topic by Brett posted 01-29-2018 11:21 AM 1197 views 0 times favorited 2 replies Add to Favorites Watch
View Brett's profile
Brett
661 posts in 2880 days
01-29-2018 11:21 AM
I purchased a vintage 1/8” Buck Bros. tang chisel that is in good condition except that the handle is a bit loose. (I can remove the tang from the handle, but the fit is otherwise pretty snug.) Is there any way to tighten the fit without using epoxy or other permanent adhesive? Thanks.
-- More tools, fewer machines.
2 replies so far
View JJohnston's profile
JJohnston
1622 posts in 3488 days
#1 posted 01-17-2015 03:06 AM
Drill out the hole, glue in a dowel, redrill the hole.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View JohnChung's profile
JohnChung
416 posts in 2271 days
#2 posted 01-17-2015 04:12 PM
Use a long shaving and then glue it to the loose handle itself. Provide enough wrappings on the handle for a good snug fit.
