What kind of finish
Forum topic by thelt posted 03-26-2009 01:01 AM 971 views 0 times favorited 4 replies Add to Favorites Watch
View thelt's profile
thelt
665 posts in 3343 days
03-26-2009 01:01 AM
Ok LJ’s, I put this together this afternoon. What kind of finish do you guys recommend? I know, It’s simple and only took a couple of hours to do, but I thought it unique. Haven’t seen any of these around here. I haven’t a clue what kind of wood the washboard manufacturer uses, but the rest is just dimensional pine. I have ideas for other washboard projects if this works out.
Flower Planter from a washboard.
-- When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
View Al Killian's profile
Al Killian
273 posts in 3717 days
#1 posted 03-26-2009 03:39 AM
Display or for use? For use a couple coats of liseedoil works good.Other would be a shellac folled by laqcuer. Looks cool.
-- Owner of custom millwork shop
thelt
#2 posted 03-26-2009 11:36 AM
Thanks Al. It will probably hold two or three small potted plants of some sort and be set out on the front porch. How about a clear coat on the metal scrub panel, should that hold off the rust?
View hObOmOnk's profile
hObOmOnk
1381 posts in 4091 days
#3 posted 03-26-2009 12:16 PM
Wiping varnish is simple and protective.
-- 温故知新
Douglas Bordner
4023 posts in 4027 days
#4 posted 03-26-2009 03:33 PM
Spar varnish if you are leaving it out. Spar contains UV inhibitors and is slightly more flexible than interior varnishes.
Or epoxy/spar varnish. If you are a FWW.com subscriber, search Sean Clarke. Or wait for the next issue of FWW magazine. I think they are planning to recycle the article. Basically Smith & Company’s MultiWoodPrime (or Clear Penetrating Epoxy Sealer) and Epifanes spar varnish.
This might be overkill over pine. Try Last-n-Last Ultra Gold Spar, McCloskey’s Man O’ War or other locally available spar varnish (Miniwax Helmsman Spar Urethane – probably).
