Ridgid R4512 Fence ad on
Forum topic by Garbanzolasvegas posted 01-17-2015 01:04 AM 880 views 0 times favorited 2 replies Add to Favorites Watch
View Garbanzolasvegas's profile
Garbanzolasvegas
356 posts in 1101 days
01-17-2015 01:04 AM
I am looking for a table saw fence add on I guess. My fence is fine and straight and all that but I would like to have an item I could ad to it where I could use the other pair of my Kreg Blue Feather boards to hold the stock from above flat against the table. Any suggestions?
Also I has seen the LEE CRAFT zero clearance insert for this saw and am going to get it and the dado insert as well BUT. I have another issue. Image that? issues with a R4512…..
With the stock insert, when I tilt the blade all the way over to do a 45 degree cut the blade Bites deep into the stock insert. This came as a huge surprise to me, not to mention sparks.
I have had to do 45 degree cuts with NO INSERT and I hate it.
Making ones own insert for this saw are problematic at best and impossible at worse. One would have to make a template and rout around where the leveling screws are. I am not prepared to do that as now
-- If you don't Play, you can't win
2 replies so far
View AlaskaGuy's profile
AlaskaGuy
3791 posts in 2183 days
#1 posted 01-17-2015 11:24 AM
Do a Google search on” table saw fence jigs”. Lot of stuff out there in you look. As an example
Garbanzolasvegas
#2 posted 01-17-2015 02:32 PM
Perfect
