Shellac over Tung Oil???
Forum topic by JimT posted 03-25-2009 03:52 AM 5510 views 0 times favorited 10 replies Add to Favorites Watch
View JimT's profile
JimT
10 posts in 3877 days
03-25-2009 03:52 AM
I should probably start with a disclaimer… finishing is not my thing, in fact I wish I didn’t have to do it. With that said, I’ve completed a small project made entirely from Brazilian Cherry and have coated it with one coat of Tung Oil. It looks great but I’d like to add a little more protection and a little more sheen, can I apply shellac over the tung oil once the tung oil has dried completely?
Thanks, Jim
10 replies so far
27250 posts in 3850 days
#1 posted 03-25-2009 03:55 AM
Yes. Shellac can be used over any undercoating once it has cured. Give the tung oil 24 to 72 hours, depending on the temperature, to cure and topcoat it with shellac.
View Chris 's profile
Chris
1879 posts in 4019 days
#2 posted 03-25-2009 04:09 AM
I would caution one thing… It may take even more time for the Tung Oil to cure if you live in a high humidity area. Here in Florida I give it several days….
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Francisco Luna's profile
Francisco Luna
943 posts in 3422 days
#3 posted 03-25-2009 04:58 AM
I would say a couple of weeks. Tung oil takes time to dry completely, specially on endgrain areas
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View John Gray's profile
John Gray
2370 posts in 3914 days
#4 posted 03-25-2009 05:14 AM
IMHO – I’d let Tung Oil cure at least a week before applying the top finish…..better safe than sorry.
View JimT's profile
JimT
#5 posted 03-25-2009 05:20 AM
Thanks for the quick replies guys… I applied the Tung oil three days ago and its almost finished “leeching” from the end grain. Like everyone suggested, I’ll give it another 4 or 5 days and see what the shellac looks like on top. I’ll post some pictures too, thanks again for all the help.
Jim
View scottb's profile
scottb
3648 posts in 4355 days
#6 posted 03-25-2009 05:45 AM
yep, just re-read today that Shellac can go over anything but wax.
-- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/
Todd A. Clippinger
8901 posts in 4128 days
#7 posted 03-25-2009 05:53 AM
I would allow the oil 1 week at least. If you are keeping it in a cool basement or garage to dry, better go two.
A finish that releases will be the epitome of frustration.
View SSS's profile
SSS
3 posts in 2577 days
#8 posted 06-04-2011 01:34 AM
Thanks for all this info. Wondering about some related advice for a mahogany butcher block table (not endgrain). I want to finish it with a few coats of tung oil and wonder if I could do a coat of Carnuba wax on top of that for additional protection from heavy use – any thoughts about whether this is a good idea?
View pastorglen's profile
pastorglen
267 posts in 2718 days
#9 posted 02-25-2012 01:25 AM
This is what’s great about this site! Almost 3 years later and this information is STILL good scoop. Thanks, LJs!!
-- Glen, Pennsylvania, Colossians 3:23 "Whatever you do, work heartily, as for the Lord and not for men."
View KenBee's profile
KenBee
109 posts in 2664 days
#10 posted 02-25-2012 04:32 PM
I use BLO under my shellac on some projects. I am trying to finish up a box that will use one coat of BLO, 3 coats of shellac and 2 finish coats of wipe on polyurethane. The only complaint I have with BLO is that it will turn lighter woods darker so I am careful what I use it on. The box I mentioned above is made from Red Oak, Walnut and Red Cedar. The BLO turned the Red Oak into a beautiful golden color, the walnut and Cedar a bit darker. I haven’t applied the poly yet but the BLO and Shellac finish makes the colors jump out in a beautiful contrast. I am hoping with the Poly being clear satin it will really set off the colors this being the first time using this combination of finishes. I also lightly rub down with a 3M finishing pad between each coat.
-- If it won't fit get a BIGGER hammer.
