Built-ins for childs playroom
Forum topic by Shanem posted 01-16-2015 06:04 PM 668 views 0 times favorited 3 replies Add to Favorites Watch
View Shanem's profile
Shanem
130 posts in 2436 days
01-16-2015 06:04 PM
Trying to sketch up a design for a few built-ins for a playroom in the basement. This room also acts as a spare room for guest. It has a pullout couch currently. I want to build a bookshelf/bench along one way. The bench i’m going to take the mechanism out of the current couch and incorporate it. I have most of that figured out.
I’m also trying to built drawers in the space under the stairs. Currently the void is 41” deep. That’s when I priced 40” metal drawer slides…. ~$140 a set at lee valley for 36”. Does anyone have a cheaper supplier? what about dovetail wood runners with slick tape? or possibly a track with castors? I’m too cheap to buy 5-6 sets at that cost.
Should also mention that the floor is carpet.
Any suggestions?
3 replies so far
View pjones46's profile
pjones46
1001 posts in 2613 days
#1 posted 01-17-2015 11:59 PM
Use hardwood runners made of hard maple, skip the slick tape and rub beeswax on them. For years the old craftsman did this and it worked fine. Every once and a while you will have to reapply the beeswax but really not an issue.
-- Respectfully, Paul
Shanem
#2 posted 01-19-2015 02:09 AM
I’ve used them for dressers but wasn’t sure they would be good for 40” and more weight.
pjones46
#3 posted 01-19-2015 02:36 AM
Unless you are going to fill them with Gold should be no problem with a reasonable weight Load and will slide without a problem.
