Garage ventilation for hot weather
Forum topic by Big_T posted 01-16-2015 05:39 AM 1364 views 1 time favorited 15 replies Add to Favorites Watch
View Big_T's profile
Big_T
119 posts in 1228 days
01-16-2015 05:39 AM
Topic tags/keywords: miter saw tablesaw router question
I am getting my shop ready but today’s wintery 83° in Deep South Florida has me thinking about ventilation. I thought about a mini-split but the garage door is not insulated. The garage is attached CBS 350 sq.ft. and ceiling is 9 feet high. Friend installed R-30 rolls last month, it helps a great deal but there is no ventilation even with the garage door fully opened.
To me it makes sense to cut open a door at the opposite corner and have a breeze just tunnel its way through the garage, but with CBS it’s no easy task and not sure the HOA would approve it.
A big consideration is I would like to keep gawkers away and just have the garage door barely open, maybe 12”, since today I opened the door to miter some scraps and people just can’t resist looking – garage voyeurs I suppose.
Any ideas appreciated.
15 replies so far
View MikesProjects's profile
MikesProjects
171 posts in 1773 days
#1 posted 01-16-2015 04:00 PM
Air (swamp) cooler, on humid days use it with out the water running, I have a large one in my shop & in the house, works like a dream.
-- -Mike, Southern California, YouTube User ( Give & Take )
View wseand's profile
wseand
2796 posts in 2912 days
#2 posted 01-16-2015 04:12 PM
What about a couple of well placed ceiling fans or just fans on stands.
Big_T
#3 posted 01-16-2015 04:14 PM
Not sure what that is but I will check youtube. Also was thinking about this and it stays cool for 3 hours:
http://www.polarproducts.com/polarshop/pc/viewPrd.asp?idproduct=2055&idcategory=172
View OSU55's profile
OSU55
1460 posts in 1860 days
#4 posted 01-16-2015 04:36 PM
Attach some foam insulating board to the garage door, or use spray foam insulation, and install either a mini split or room/ window AC. You probably don’t need much if any heat. I’m in Missouri and find having the shop air conditioned in the summer is nice. One big plus is it keeps the bugs out in the evening. Also, for S. Florida, conditioning the space and dropping the humidity would help when applying finish to your projects. I goota believe your shop is a real sweat box in the summer!
View dhazelton's profile
dhazelton
2648 posts in 2167 days
#5 posted 01-16-2015 04:41 PM
What is CBS?
wseand
#6 posted 01-17-2015 02:34 AM
Concrete Block and Stucco. (CBS)
View distrbd's profile
distrbd
2252 posts in 2317 days
#7 posted 01-17-2015 04:31 AM
It’s hard to imagine 83° when we are going through -24°C(-11°F) up here in Ontario.
-- Ken from Ontario, Canada
View Hermit's profile
Hermit
144 posts in 1196 days
#8 posted 01-17-2015 04:37 PM
I would put in a small whole house fan in the ceiling of your garage providing you have adequate attic ventilation to the exterior. The cheap ones at the box stores should be avoided as they are very noisy and less reliable. A 24” fan would be more than plenty in a garage but would require at least 24 square inches of attic ventilation to the exterior. Open up your garage door equal to 24 square inches, turn the fan on and you’ll cool that garage off in about 3-5 minutes or less. http://www.wholehousefan.com/
-- I'm like the farmer's duck. If it don't rain, I'll walk.
View BigYin's profile
BigYin
405 posts in 2287 days
#9 posted 01-17-2015 04:48 PM
Hermit … http://www.wholehousefan.com/
I tried to go to the site but got the message “You Are Banned From Viweing This Website”
-- ... Never Apologise For Being Right ...
Hermit
#10 posted 01-17-2015 05:59 PM
It did that to me also. Hit cancel and the page should load.
Big_T
#11 posted 01-17-2015 11:10 PM
Hermit: Wow thanks for that link, it looks interesting and should solve my problem
distrbd: Last night we had a cold front and temps dropped to 59 F, but today it’s back in the 80s.
dhazelton
#12 posted 01-18-2015 01:59 PM
Don’t know your garage door construction, but if one piece can you put an opening window into it in conjunction with the fan? The small basement type that just opens out…
wseand
#13 posted 01-18-2015 11:04 PM
Big Yin,
Dont worry about being banned, I have been from better sites then that one. Your in trouble if you go here and your banned. :-)~
Big_T
#14 posted 01-29-2015 12:39 AM
Did some reading and WHF says it’s never lower than outside temps, so I am not sure how that would work in the rest of my house when during summer it’s 95 outside and I would like to save on my $300 electric bill.
For the garage I think it’s a good idea, but first I am gonna fiddle with improving the the door insulation and using a portable AC for now. The old 10k BTU I have only operates on 68 or 74 degrees, but either temps should be fine for working just an hour or so per week.
View KDO's profile
KDO
154 posts in 2640 days
#15 posted 01-29-2015 02:01 AM
Big_T, the squirrel cage fan from a Swamp Cooler would move a lot of air, and you could direct the air with proper ducting, but you couldn’t buy a Swamp cooler in Florida if you wanted to.
They are good for dry climates, but not down here.
The squirell cage fans do move a lot of air, but you would need to be able to cool the air somehow.
Bummer that the HOA can control what you do.
I like the idea of a WHF and good insulation, and a portable AC unit that you could vent outside through a “dryer vent”.
Another benefit of the AC unit is that it would help reduce the humidty (if that’s possible in Florida).
Good luck, and I would like to hear what you finally do.
-- Christian, Husband, Grandpa, Salesman, amateur Woodworker.
