Rustic live edge bench
« back to Joinery forum
Forum topic by PhillipRCW posted 01-15-2015 09:38 PM 1036 views 0 times favorited 7 replies Add to Favorites Watch
View PhillipRCW's profile
PhillipRCW
462 posts in 1166 days
01-15-2015 09:38 PM
Is there another way that works other than mortise and tenon joint to attach legs perpendicular to a live edge slab? I have seen it screwed together with pocket holes, but it doesn’t look good like that to me. There won’t be an apron, just the three pieces of wood for legs and bench top.
-- Phillip- Measure twice, cut onc.... Hey look, it's rustic.
7 replies so far
View MBD's profile
MBD
72 posts in 1787 days
#1 posted 01-15-2015 09:58 PM
Dowels glued in to the end of the leg, then stand the leg on the bottom of the seat and mark your holes and drill just deep enough not to go all the way through.
-- Matt, Mississippi
PhillipRCW
#2 posted 01-15-2015 10:01 PM
That was the other option I was thinking of. I have some leftover dowels right now and the slabs are 2”+ thick. Plenty of room to do this. Think a 1” dowel would be overkill?
View Timberwerks's profile
Timberwerks
360 posts in 3063 days
#3 posted 01-15-2015 10:31 PM
Why are you looking to do something other than M&T?
-- https://www.facebook.com/pages/Timberwerks-Studio/126415221682
PhillipRCW
#4 posted 01-15-2015 10:38 PM
Because I haven’t experimented a lot with joinery techniques. I know how to do dovetails, but I’m about the only person in the world who doesn’t really like the look of it. I would just like to expand my abilities if possible instead of always going to the same technique. Plus I just got my new table saw and haven’t had time to set it up yet. Partially out of laziness.
View gfadvm's profile
gfadvm
14940 posts in 2592 days
#5 posted 01-16-2015 01:37 AM
Figure 8 table top connectors would be easy and work well but I would add a stringer between the legs to reduce ‘wobble’ factor.
PhillipRCW
#6 posted 01-16-2015 01:53 AM
I honestly had never seen those before. I think I’m going to try the dowels this time since I have it on hand. I want to avoid the stringer if possible. Just don’t want it on this bench.
gfadvm
#7 posted 01-16-2015 02:13 AM
I have had problems with wobble without the stringers. Angling the legs outward at 15 degrees does help but I still like a stringer. My grandkids may be harder on benches/coffeetables than your intended usage!
