| Forum topic by snowdog | posted 854 days ago | 291 views | 0 times favorited | 6 replies | ![]() |
854 days ago |
Ogee Stile & Rail Bit 1 – 5/8 ” BOSCH I am making a frame to hold Plexiglases (smoked) for a pantry door. I have never used a router bit set before and want to check with you guys (and gals) to see if there is anything wrong with with my method or the bit set. It seems like the stile and rail are to tight, I can’t push them together to make a tight joint. I can put a clamp on it and jam it together but from all I have heard, if a joint is to tight it will be “glue starved”. Might the set be milled wrong? Is it something I am doing wrong? I have a router lift kit on my table saw extension table and push the rails and stiles through, the joints lines up pretty well, after a few test scrapes to get the hight adjustment just right. I can not see what I would be doing wrong , but then that is why I am asking :) Your thoughts? -- "so much to learn and so little time".. |
