how to glue up a door frame
Forum topic by alaskan79 posted 03-23-2009 04:08 AM 1793 views 0 times favorited 5 replies Add to Favorites Watch
View alaskan79's profile
alaskan79
74 posts in 3348 days
03-23-2009 04:08 AM
Hi
I am thinking of making a clock and the front of it is going to have a door with a glass pane in the middle. What is the best way to glue up the frame to keep it square. I was thinking of using miters for the corners.
Thanks Henry
-- alaskan79, Michigan
5 replies so far
View lew's profile
lew
12056 posts in 3751 days
#1 posted 03-23-2009 04:23 AM
Coped rails and stiles are very strong because of the large amount of glue surfaces.
I made a grandfathers clock using this method. It has beveled glass and has remained square for many years.
View jeh412's profile
jeh412
129 posts in 3370 days
#2 posted 03-23-2009 03:21 PM
Rail and stile router bits would be my first choice since it gives good glue surfaces and finishes the inside edges around your glass or panel. If you don’t have those bits, half lap joints or mitered half lap will give you good glue surfaces and a strong joint. Miters alone will work, since picture frames are done this way all the time, but it wouldn’t necessarily be the best for a door.
-- John, co-owner Sawdust 'n Stitches
View Don Butler's profile
Don Butler
1092 posts in 3391 days
#3 posted 03-23-2009 03:38 PM
Miter joints are one of the weakest joints in all of woodworking. The joint consists of gluing end grain to end grain, which simply doesn’t work well.
But, if you feel that’s the way you want to go for the sake of appearance, please use a spline to reinforce it. Just make the miters and let the glue dry well. Then make yourself a little sled that will run against the rip fence of your saw and put blocks in it that will hold the frame edgewise to the saw blade and with the mitered frame blocked up at a 45ยบ angle to the table. Make a slot through each corner and glue a spline in the slot. Make sure that the grain of the spline runs across the miter joint so it’ll resist forces that wrack the joint.
d
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
alaskan79
#4 posted 03-24-2009 05:42 AM
Thanks for the info. The type of clock I am thinking of making is a bracket clock using white oak. I think that I will use a rabbeting bit to make a rabbet to hold the glass then make a tenon on the end of the top and bottom piece. To fit the rabbet in the 2 side pieces and glue them up that way so it looks kind of old fashion. The tenon should come out the same length as the depth of the rabbet by using the same bearing on the bit.
Henry
View Frankie Talarico Jr.'s profile
353 posts in 3352 days
#5 posted 03-24-2009 11:34 PM
What about lap joints? those seem to work well if your looking for a square inside profile. Thats maximum glue surface. Just set up you table saw and make two cuts. Very fast and easy, but it all depends on the look your going for. I also favor stile and rail, but I usually prefer an inside profile.
-- Live by what you believe, not what they want you to believe.
