bowl blanks
« back to Woodturning forum
Forum topic by 3285jeff posted 01-15-2015 12:35 PM 956 views 0 times favorited 7 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
152 posts in 1742 days
01-15-2015 12:35 PM
im new here and am wanting to turn a few bowls,,i have access to a lot of hard rock maple flooring,,would this be ok to glue up and use to turn a board,,
7 replies so far
3285jeff
#1 posted 01-15-2015 12:36 PM
excuse me I meant glue up and and use to turn a bowl,,sorry,,
View Bluepine38's profile
Bluepine38
3379 posts in 3109 days
#2 posted 01-15-2015 06:00 PM
Is it used or new, if used, you will have to clean it to get it glueable. If it is hard maple, it could be a challenge
to turn and require you have sharp tools and sharpening method to keep them sharp. Be sure to wear a
face shield while turning any glued wood and try to make the shape as round as possible before starting to
turn at a slow rpm. You did not state your level of experience, so you might need to start with some turning
lessons.
View Woodknack's profile
Woodknack
11775 posts in 2404 days
#3 posted 01-16-2015 05:33 AM
Google “bowl from a board” and “segmented turning”. You could glue up a solid block but then you’ll just have to cut away most of it.
View Ron Ford's profile
Ron Ford
208 posts in 1756 days
#4 posted 01-17-2015 07:44 PM
Absolutely. As Gus said, be sure it is clean and smooth before gluing up. I have a Jet 1632 drum sander and it is one of my favorite tools for prepping wood for glue-ups. I use Titebond II glue and have never had a failure with it. Give the wood a medium coat, making sure there are no voids, then clamp or weight for 24 hours before turning. I think you’ll find that it works well.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
View JoeinGa's profile
JoeinGa
7736 posts in 2031 days
#5 posted 01-17-2015 11:28 PM
You mean you want to do something like this?
Works just fine for me!
3285jeff
#6 posted 01-17-2015 11:46 PM
man that is some kinda nice,,,what wood were you using,,and what kind of finish did you use,,
JoeinGa
#7 posted 01-18-2015 09:36 PM
That one is all maple. I “clocked” each piece so the grain runs opposite of each other in the layers. I finished it with Tung oil and spray lacquer.
You can see it here ... http://lumberjocks.com/JoeinGa/blog/43374
