Having trouble removing legs from chair
« back to Joinery forum
Forum topic by maxhall posted 01-14-2015 11:58 PM 1051 views 0 times favorited 6 replies Add to Favorites Watch
View maxhall's profile
maxhall
80 posts in 2439 days
01-14-2015 11:58 PM
Hey everyone my wife picked 4 of these chairs up a while back for our dining room and I’m finally getting to them. As is the case with most old chairs several of the joints are loose so I was planning on diassembling, cleaning out old glue, regluing, and clamping them back together. I can’t for the life of me figure out what is holding this front leg on. I removed the screw from the brace underneath (which appears to be the only fastener holding it in place, I know this doesn’t make sense, should be more to it than that) I removed the fabric from around the leg in question and made sure it wasn’t nailed/screwed from the top wooden support into the top of the leg. I can wiggle the leg about an 1/8” but the leg is staying put. My only guess is that behind the brace there may be a screw joining the leg to the frame, I just cant tell because of the brace. The brace is nailed and screwed on either side, so removing the nails may be a bit of a challenge.
Any ideas of what could be holding that leg in place?
Also how would you stabilize the leg? I feel it needs something else to make it more stable.
View pjones46's profile
pjones46
1001 posts in 2880 days
#1 posted 01-15-2015 04:44 AM
Normally there is a hanger bolt thru the brace into the leg,sometimes I have seen a wood screw vs the hanger bolt. Were you able to remove the semicircular support? Could be even wood dowels into the leg from the sides.
-- Respectfully, Paul
View Greg In Maryland's profile
Greg In Maryland
553 posts in 3235 days
#2 posted 01-15-2015 04:58 AM
Have you removed the cushion? Perhaps there is something from the top?
Greg
View realcowtown_eric's profile
realcowtown_eric
617 posts in 2174 days
#3 posted 01-15-2015 05:00 AM
In the third picture, is that a filled nail hole i see? Check it out with a rare-earth magnet.
good luck
Eric
-- Real_cowtown_eric
View SilverbackReef's profile
SilverbackReef
20 posts in 3190 days
#4 posted 01-15-2015 02:32 PM
Doing some chair repair myself at the moment and ran across this article:
http://www.popularwoodworking.com/techniques/finishing/regluing_doweled_chairs
He recommends removing the braces first. Good luck!
View gsurgeon's profile
gsurgeon
3 posts in 2338 days
#5 posted 01-15-2015 06:25 PM
The leg is more than likely doweled to the skirt. The brace seems to be still held in place with some glue. See if warm water will make the glue sticky. This would tell you whether or not it’s hide glue. If it is, you can try and get some hot water into that joint and it should come apart.
View Dallas's profile
Dallas
3599 posts in 2725 days
#6 posted 01-15-2015 06:32 PM
If the glue is hide glue, use the hair dryer that your wife owns, (just be prepared to buy her a new one.
Hide glue will soften and be reusable even after 100 years. Just add more hide glue in the proper way.
If it is PVA glue, (Titebond or Gorilla wood glue, it will soften, but isn’t reusable).
