Use of a table saw as a joiner
Forum topic by jav posted 03-22-2009 09:20 PM 1867 views 0 times favorited 3 replies Add to Favorites Watch
View jav's profile
2 posts in 3287 days
03-22-2009 09:20 PM
Topic tags/keywords: table saw as a joiner
I have read much about using a router table as a joiner (until I can afford a dedicated joiner). I thought that a table saw with a long sacrificial fence and shims on the outfeed saw of the saw blade could work . I will bury the saw blade in the sacrificial fence on the infeed side and align the outer edge of the sw blade with the thicker fence on the outfeed side. I was considering two widths of cuts. The full 1/8 inch blade width and a 1/16 width. Other smaller widths are also possible. the material providing the extra wdths would be attached to the fence with double stick tape.
How does ths sound?
3 replies so far
View marcb's profile
768 posts in 3608 days
#1 posted 03-22-2009 09:21 PM
I have a book with a jig like that in it someplace.
decent for edge jointing if you don’t have a jointer. Not sure how you’ll handle face jointing though.
View Miket's profile
308 posts in 3707 days
#2 posted 03-22-2009 09:25 PM
Just get a long piece of aluminum angle stock and hot glue it along one edge of your stock. Run that along your fence and you can cut a very nice straight edge.
-- It's better to have people think you're stupid rather than open your mouth and remove all doubt.
View papadan's profile
3584 posts in 3303 days
#3 posted 03-22-2009 10:26 PM
I had a 6” delta jointer for a while, little bench top took too long to joint the boards. I always use a straight edge and router for edge jointing, find it to be precise and aster than a jointer. Here is a little tutorial i made a while back.
