Flattening 1/4" Plywood
Forum topic by interpim posted 03-22-2009 06:32 AM 1519 views 0 times favorited 3 replies Add to Favorites Watch
View interpim's profile
interpim
1170 posts in 3333 days
03-22-2009 06:32 AM
Topic tags/keywords: question plywood
I have some 1/4” Oak Plywood, which has a slight bow to it. The panels I cut from it are fairly small (13” x 18”) and still retain this bow.
I have the panels raised from each end by a couple of 2” boards, and put another board in the center and added weight. Will this flatten the plywood back out? or should I try something else to get it flat?
-- San Diego, CA
3 replies so far
35097 posts in 4275 days
#1 posted 03-22-2009 06:38 AM
What is the ply going to be used as. Is there any other wood that can hold it flat?
View PurpLev's profile
PurpLev
8534 posts in 3524 days
#2 posted 03-22-2009 06:44 AM
usually 1/4” ply is used as a backer board, or a drawer bottom where it is held/fastened to a square frame which keeps it flat. 1/4” ply on it’s own will hardly stay flat.
View DaleM's profile
DaleM
958 posts in 3259 days
#3 posted 03-22-2009 12:52 PM
I just had the same problem and it seemed that bending alone wasn’t taking the warp out. I sprayed it down with water on both sides, enough to penetrate a little, then weighted it down for awhile until it dried. It worked, sort of. It retained a slight bow in the other direction when it dried. I guess I had curved it too much, or wet it too much but it looks like it will work with some trial and error while I figure it out.
-- Dale Manning, Carthage, NY
