Finishing curly whit oak
Forum topic by jrhannegan posted 01-14-2015 05:20 AM 741 views 0 times favorited 3 replies Add to Favorites Watch
View jrhannegan's profile
jrhannegan
12 posts in 1227 days
01-14-2015 05:20 AM
Topic tags/keywords: curly maple curly oak white oak
Hey guys,
I am a newbie at wood working, but I am trying to build my brother a coffee table for his wedding present. I was going to do quarter-sawn whit oak, when I stumbled upon curly oak. Of course, I fell in love with it. I am planning to make the table top and bottom shelf out of this and forge the frame and legs in my blacksmith shop. Making the top and shelf should be a simple glue up, then I’ll have a friend to run it through his sander. My big question is how to finish this wood. I want to maintain the shimmer and depth of the figure, but I don’t want a raw look. Also, since this is a coffee table the surface has to be pretty durable. Does anyone have any ideas how I can show off the wood while adding color and protection?
3 replies so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2528 days
#1 posted 01-14-2015 06:06 AM
Just about any film-forming finish will work in that application. Polyurethane, lacquer, conversion varnish, etc. Sprayed or wiped. Since you want color, probably something oil-based, although there are some water-based products that add color.
How much color you are looking for might be the first place to start.
-- Mark Kornell, Kornell Wood Design
Mark Kornell
#2 posted 01-14-2015 06:08 AM
Also, welcome to LumberJocks.
jrhannegan
#3 posted 01-15-2015 05:01 AM
Thanks Mark,
I want it to have a hint of red to accent the figure or grain so that it will have some warmth. Also, I want to make it a little more rich. I tried dying the wood with a diluted solution of Emperial Red dye then applying boiled linseed oil. It looks okay, but that red is a little stark. I will try a more toned down dye on the next test. I think that will give me a color that I like. The big question for me is will those finishes you recommended impair the interesting refractions in the figure? I have seen people using danish oil or wax that works really well, but will that be durable enough to handle being a coffee table surface?
