What wood for white stain finish
Forum topic by Joel_B posted 01-14-2015 02:57 AM 905 views 0 times favorited 5 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
335 posts in 1251 days
01-14-2015 02:57 AM
I had planned to make some bedroom furniture from Cherry.
But the plans changed since we bought a temporary dresser from Ikea that has a white stain finish and my wife like it better than cherry because it goes well with the hickory hardwood floors and yellow walls.
I am still doing the bed in Cherry because the style probably won’t look right in white.
I am thinking to use cherry for the tops of the dressers and rest white stain. So I am looking for a wood that will look good with white stain on it. I am thinking the stain will be somewhat transparent so the wood grain will show through. My thoughts right now are white ash or white oak.
-- Joel, Encinitas, CA
5 replies so far
View firefighterontheside's profile (online now)
17195 posts in 1726 days
#1 posted 01-14-2015 03:00 AM
I did a china corner cabinet out of birch and white washed it to match an older piece we had. I think it turned out good.
Joel_B
#2 posted 01-14-2015 03:32 AM
- firefighterontheside
Any pictures?
This is sort of what I had in mind. I kind of like the grain of ash.
View Yonak's profile
Yonak
986 posts in 1391 days
#3 posted 01-14-2015 04:35 AM
Joel, if you come up with a method that works well, please report what it is.
I’ve got a project going now in ash that I want to be stained white somehow as it’s something I will attach to the ceiling and I want it to blend in as much as possible. I was planning on experimenting with pickling and bleaching techniques as well as thinning white paint with Penetrol and applying as a stain to see the result.
Joel_B
#4 posted 01-14-2015 05:20 AM
I ve got a project going now in ash that I want to be stained white somehow as it s something I will attach to the ceiling and I want it to blend in as much as possible. I was planning on experimenting with pickling and bleaching techniques as well as thinning white paint with Penetrol and applying as a stain to see the result.
- Yonak
Minwax makes a white wash pickling stain that I might try on a sample pice of ash.
If you search around you can find some projects that used it and turned out pretty nice.
General finishes also makes a white wash stain.
#5 posted 01-14-2015 02:02 PM
This is the only picture I have. I watered down some white latex paint and wiped it on with a rag and then wiped it back off like I would do with any stain. Then I put water based poly over it. The things don’t like about birch is that it likes to chip when planed. This was way early in my woodworking experience.
