what type of wood is this??
Forum topic by BigBard posted 03-21-2009 05:51 AM 1192 views 0 times favorited 6 replies Add to Favorites Watch
View BigBard's profile
BigBard
114 posts in 3647 days
03-21-2009 05:51 AM
Topic tags/keywords: question
I found a lot of this wood in a dumpster and I am very curious to know if i have some expensive wood. I gonna use it on something regardless, but it will be nice to know what type is…
wood type 002
-- Carolina Panther fan!
View DaleM's profile
DaleM
958 posts in 3617 days
#1 posted 03-21-2009 08:54 AM
The fourth piece from the left looks like poplar, but other than that, I don’t know. What I do know is it looks good and I’m looking forward to see what you make from this.
-- Dale Manning, Carthage, NY
View jack1's profile
jack1
2117 posts in 4261 days
#2 posted 03-21-2009 10:51 PM
I’m going to say hemlock. I got a bunch of wood from someone that gets his AC units in protective frames and made some frames etc out of it. When I stained it, it looked a lot like this especially the 4th board from the left with that dark streak. The pieces I got were the size of 3×2’s. It worked well and took up stain nicely. Hope I was helpful.
BigBard
#3 posted 03-21-2009 11:26 PM
thanks, I gonna research Hemlock.
BigBard
#4 posted 03-22-2009 05:30 AM
after doing some research I believe its a wood called goncalo alves, I would be hard pressed if someone said otherwise. Check these links and see what you think. http://www.hobbithouseinc.com/personal/woodpics/goncalo%20alves/goncalo%20alves%20end%20grain%201%20s25%20q60%20plh.jpg I have a piece that looks just like this.
http://www.hobbithouseinc.com/personal/woodpics/#letterH
TopamaxSurvivor
18422 posts in 3909 days
#5 posted 03-22-2009 09:29 AM
It looks too nice for hemlock. Is it a hardwood?
View daltxguy's profile
daltxguy
1373 posts in 4147 days
#6 posted 03-22-2009 12:49 PM
red gum ( sweet gum), maybe?
-- If you can't joint it, bead it!
