Jewlery Box lid support
Forum topic by TurnTurnTurn posted 01-14-2015 02:29 AM 1309 views 0 times favorited 6 replies Add to Favorites Watch
View TurnTurnTurn's profile
TurnTurnTurn
613 posts in 3108 days
01-14-2015 02:29 AM
Topic tags/keywords: jewlery box help trick question tip
I had to use butt hinges on a jewelry box. To get the lid to stop a little past 90 degrees I thought I could use a piece of costume jewelry chain, I bought a rather hefty chain that is relatively hard to pull apart by hand, but as soon as I attach it to support the lip of the box is snaps immediately. So this chain is not substantial enough to support the lid. Does anyone have any other suggestion as to what I might use to support the lid. Thanks
-- TurnTurnTurn
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#1 posted 01-14-2015 02:36 AM
I have glued a small “stop block” on the back of boxes as I really do not like chains!
TurnTurnTurn
#2 posted 01-14-2015 02:43 AM
Thx for the tip gfadvm. I just checked out some of your projects, great stuff.
-- TurnTurnTurn
View kiefer's profile
kiefer
5619 posts in 2665 days
#3 posted 01-14-2015 03:00 AM
You could do this, a simple piece of leather attached to the lid and box .
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
View ElChe's profile
ElChe
630 posts in 1335 days
#4 posted 01-14-2015 01:21 PM
What about a butt hinge with a built in stop like a brusso jb-101? It does require a full mortise and Some chamfering but they are really sweet and pricey. Other manufacturers make stop hinges in various dimensions. I find chains to be a PITA because they break!
View OnhillWW's profile
OnhillWW
130 posts in 1231 days
#5 posted 01-14-2015 02:56 PM
kiefer,
I really like the look of the leather – how do you secure the ends of the leather so that it does not pull out? Do you find that the leather stretches much over time with use?
-- Cheap is expensive! - my Dad
kiefer
#6 posted 01-15-2015 03:21 AM
OnhillWW
I use CA glue and it seems to hold good on leather and stretching seems to be no issue .
I have used leather for hinges also, if you look in my project posts you will find several boxes with them round and square types and one or two with a round dovetail .
Give it a try .
Klaus
