Forum topic by cdnstudentwoodworker | posted 01-14-2015 12:58 AM | 1256 views | 0 times favorited | 15 replies | ![]() |
Topic tags/keywords: question oak drill-driver joining No pictures until tommorow , i was working on my roll top desk. Where the side of the desk that has the curved dado for the tambour door , i was screwing the top of the case down. Lacking a brain at that moment i screwed to close to the front edge and the pointy end of the screw went through the dado and would block the movement of the door. This wouldnt be a big deal but the screw had been plugged with a wooden dowel before i noticed. Both sides of the desk are like this. Any help on how to remove the screw would be appreciated. |
15 replies so far
#1 posted 01-14-2015 01:03 AM |
Dremel tool? -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#2 posted 01-14-2015 01:36 AM |
Just grind the protruding ends off. Dremel tool, die grinder, etc. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#3 posted 01-14-2015 01:43 AM |
Good ideas above as well. Maybe a hack saw? |
#4 posted 01-14-2015 01:47 AM |
If you can still remove the screw ,it would look cleaner if you just shorten it and screw it back in,if it’s not accessible,then carefully grind it,don’t forget to wear eye protection. -- Ken from Ontario, Canada |
#5 posted 01-14-2015 01:48 AM |
+1 -- I'll bulid your dream,you tear it down. |
#6 posted 01-14-2015 01:53 AM |
Wahoo,I just found a use for my electric narrow belt sander : -- Ken from Ontario, Canada |
#7 posted 01-14-2015 02:01 AM |
Nice sander Ken. |
#8 posted 01-14-2015 02:24 AM |
Probably going to have to sacrifice a forstner bit and drill out the plug one size bigger so that you can unscrew the screw and put a new plug back in. I recommend using a forstner bit because it will leave a clean hole to re-plug. -- Because I'm gone, that's why! |
#9 posted 01-14-2015 03:35 AM |
Carefully center-punch the center of the dowel and use a bit about half the diameter of the plug to put a hole in the punched location. Work carefully and start stepping up to larger diameter bits and drill bigger and bigger holes until almost all the dowel is gone. If you’re lucky, the remaining dowel pieces will crumble and fall out. If the remnants of the dowel don’t want to give way there’s still hope. If you used wood glue to install it, heat up some vinegar and dab it into the hole. Repeat this operation until the remains of the dowel can be pried out with a gentle nudge from an awl. -- See my work at http://remmertstudios.com and http://altaredesign.com |
#10 posted 01-14-2015 03:59 AM |
This is why in wooden boat construction (bright work, planking) it is (was) customary to use varnish to stick the plugs in, rather than glue. -- I admit to being an adrenaline junky; fortunately, I'm very easily frightened |
#11 posted 01-14-2015 04:37 AM |
When this happens I take a sheetrock screw and just drive into the center of the plug. When the point of the sheetrock screw hits the other screw head the plug will come loose and you can remove it and the screw. You may have to re-drill the plug hole to clean it up. -- Bondo Gaposis |
#12 posted 01-14-2015 12:05 PM |
+1 Bondo, but of course you’ve got to catch it before the glue cures, if you’re under 24 hours, a heat gun might bring it loose for the screw trick to work -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#13 posted 01-14-2015 01:00 PM |
I have no better ideas than those above, but I’m impressed with the array of solutions provided. I like reading this kind of thread to learn how to deal with problems in the future, even if they’re not exactly THIS problem. Thanks and good luck. -- You've got to be smarter than the tree. |
#14 posted 01-14-2015 01:52 PM |
-- In a time of universal deceit (today)- telling the truth is a revolutionary act. George Orwell |
#15 posted 01-23-2015 03:26 AM |
Best option was to use a small drill bit to locate the square recess in the screw and then drill out the plug , dremel tool didnt work out , bought one just to try it! |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6695 |
28064 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
