Can I fix this mistake?
Forum topic by wookus posted 01-13-2015 10:49 PM 1442 views 0 times favorited 10 replies Add to Favorites Watch
View wookus's profile
wookus
9 posts in 2112 days
01-13-2015 10:49 PM
I’m in the process of making speaker cabinets out of solid oak. I have glued them up into nice boxes using my Festool Domino machine. In the process of cutting the mortises for the dominos I could not see the pencil marks on the end grain of the tops, so without thinking, I used a Sharpie permanent marker to darken the lines. I can’t believe I did something this stupid, but I did, and I did it on all the boxes.
I tried cleaning the marks off with isopropyl alcohol and with acetone and neither worked. Even sanding like crazy hasn’t helped much since the marker seems to have penetrated far into the wood.
I can cover the endgrains of the tops of the cabinets with trim boards, but I’m wondering if there is a way to get rid of the marks instead.
Does anyone have any ideas on how to eliminate the lines I drew with the Sharpie?
10 replies so far
View dawsonbob's profile
dawsonbob
2819 posts in 1720 days
#1 posted 01-13-2015 11:02 PM
Try Mr. Clean Magic Eraser. Just be sure to rinse well afterward. Don’t know how it will work on wood, but it’s save my bacon a few times.
-- Mistakes are what pave the road to perfection
View Buckethead's profile
Buckethead
3194 posts in 1833 days
#2 posted 01-13-2015 11:40 PM
I think the sharpie probably made it in pretty good. No topical cleaning is likely to remedy this in my opinion. Especially at the end grain.
I’d break out the block plane to find out if a few passes is sufficient to remove it. If not, I’d consider an espresso stain. I think oak looks good like that, but I’m guessing you’re trying to fit these cabinets into an environment that may have your color selection already set.
-- Support woodworking hand models. Buy me a sawstop.
View woodchuckerNJ's profile
woodchuckerNJ
1269 posts in 1598 days
#3 posted 01-13-2015 11:45 PM
Try sticking the end in a bowl of denatured alcohol.
dipping in and out.
It won’t hurt the wood, and it should remove a lot of the color as it drips out color slowly.
No it won’t remove it all , but it might make it almost un-noticeable.
-- Jeff NJ
Rick Dennington
5805 posts in 3159 days
#4 posted 01-14-2015 12:15 AM
Lighter fluid or naptha…....
View AandCstyle's profile
AandCstyle
3025 posts in 2221 days
#5 posted 01-14-2015 12:17 AM
You could try using bleach on a sample piece. This article might be helpful.
-- Art
View TheFridge's profile
TheFridge
9249 posts in 1450 days
#6 posted 01-14-2015 12:37 AM
Oak end grain will suck it up. Good luck bud.
Craftsman on the lake
2781 posts in 3402 days
#7 posted 01-14-2015 12:49 AM
A sharpie (used to be a school teacher and used them on acetate) is soluble in rubbing alcohol. It’s probably seeped into the grain deep so soaking that corner might do it.
wookus
#8 posted 01-14-2015 08:18 AM
Thank you all for the ideas. The cabinets are each about 30” tall by 16” wide by 15” deep, so the best I could do was saturate the end grains in the suggested chemicals. Unfortunately, Sharpie is true to its name when it says “permanent.” The marks have just penetrated the wood too far.
Buckethead, I’d like to try your idea of using espresso stain. That could look especially nice if I could use it just on the tops of the cabinets. I like the look of contrasts. I have no experience using stains. Is there a particular brand and kind of stain you, or any of the others could recommend to me?
Thanks to everyone, I really appreciate your ideas.
Dave
Buckethead
#9 posted 01-14-2015 12:07 PM
Wookus, I’m not particularly knowledgeable about stains. In fact, I don’t recall ever having used any. That said, there is a wealth of information on this site about stains and their application. Many folks here have mastered the art.
View ElChe's profile
ElChe
630 posts in 1301 days
#10 posted 01-14-2015 01:34 PM
I feel for you wookus. Through decades of experience with sharpies I have come to the conclusion that sharpies are useful in only two situations: marking golf balls and leaving stains on my fingers seemingly forever. I once marked a golf ball and put the sharpie in my mouth felt tip side in. I had a sharpei type tongue for awhile. Shot a 77 so there’s that. Darker stain might help. Solvent in thin baking pan might let you soak the edge grain. Good luck.
