| Forum topic by Divotdog | posted 255 days ago | 765 views | 2 times favorited | 14 replies | ![]() |
255 days ago |
Has anyone ever used magnets to hold a lift-off lid? I ask this question because I made a box with a frame and panel lid. I was intending to use some cool invisible hinges but thanks to sorry planning (:> I realize the lid is too thin for these type hinges. It has a red oak frame about 3/8 thick, with rounded edges. The panel is resawn soft maple and is in a slot about 1/4” deep. I think this design would also prevent using a rabbet on the bottom. So I though of using magnets mortised into the box sides and (slightly) into the lid frame. The box is about 10 X 6 and the lid frame is about 1 7/16 wide – so it’s not very heavy. I dont really want to use a hnge visible from the outside – mainly because of the rounded frame edge – but I may have to. I also wonder if a magnet only about 1/16” thick would really keep a lid in place. And I wonder if a frame and panel lid should be a lift-off type anyway – would hardware placement be awkward? – Thanks, David -- David, Dallas,Tx - golfing weather is nice but so is woodworking! |
255 days ago |
Inlay some rare earth magnets and cover them with veneer. They will be absolutely invisible and they will hold way more than the whole box. Actually you should choose them carefully to avoid putting on some too strong ones. A couple of places you can get very valuable info are: Insert the usual disclaimer here, I just pull the sites from my bookmarks. EDIT: I was looking at one of the pages and found these for you. Each one is rated at .9 lbs of force for a disc of a mere 5/32 in diameter and just shy of 1/16. And at 15¢ apiece they definitely won’t kill the budget (they have a minimum order though). -- Jojo, shopless in Kyoto · http://twitter.com/kagushokunin |
255 days ago |
I was also going to suggest some rare earth magnets. We use Neodymium-Iron-Boron (NdFeB) at work and they are amazing. I see some magnets on this site that look like they may be what you are looking for. Also, there are some on the surplus page at K&J that Jojo linked to. Make sure you use an appropriate epoxy to install the magnets and don’t drop the magnets on their own as they are brittle. -- Kyle Shipp, http://battleshipp.blogspot.com |
255 days ago |
These sites are right on the money – thanks, guys. Now I need to consider how the lid should lift – maybe I will upload a pic later. -- David, Dallas,Tx - golfing weather is nice but so is woodworking! |
255 days ago |
We use reare earth mags at work. I made a tank bag for my bike out of some rare earth mags I got on ebay. Sewed them onto soft suede then onto the back of the bag added wings. Stick it on does not scratch the gas tank and even at 80 it does not go anywhere. Just be aware of the amout of hold try before you commit. -- Measure once cut twice....oh wait....ooops. |
254 days ago |
I have a document showing how to use a couple of rare-earth magnets to achieve a swivel lid if you would be interested. Also, from personal experience – make sure when you install your magnets that you have dissimilar poles facing each other, Just doesn’t hold a lid or door worth crap when you havr N-N or S-S facing one another! Jim |
250 days ago |
Jim that document you mention seems interesting. Any chance to get it? -- Jojo, shopless in Kyoto · http://twitter.com/kagushokunin |
250 days ago |
I use super magnets quite often in various applications, especially as “latches” for boxes. I buy from these guys GaussBoys great prices, good selection and reasonable shipping. The 2 or 3mm disks would probably be enough pull, I have a bunch of the 6X1mms and I am amazed at how strong they are. |
250 days ago |
I’ve used magnets for a box I made & they were 1/4” in diameter & 1/8” thick, the neat thing about these is these magnets have a hole in the middle so all you have to do is drill your hole put a magnet with a cut down finishing nail just sticking through lower the lid & it will show you a mark for you to drill the matching hole, I used one magnet in opposit corners, worked OK. -- john, Moose Jaw, Sask, j.soika@shaw.ca |
249 days ago |
Hey Jim – How can I access your doc on using magnets? And boxman – Can you tell us your source for the center-hole magnets? Thanks for all the info – I bought some cheap neodymium magnets at Harbor Freight just for testing. They are 1/4” diameter and 1/16” thick – and yes, it is surprising how strong they are. I am still wondering if I will be able to cover them nicely – I have a red oak box and I do have some red oak iorn-on veneer tape but I have never used it. -- David, Dallas,Tx - golfing weather is nice but so is woodworking! |
248 days ago |
Divot, Your thread came up at a perfect time…I am planning magnets for a box project as well…although just as a closure in conjunction with hinges. Good info here. Couple of side questions for thoes of you who have used magnets for lids…What do you use to afix the magnets? And do you use magnets top and bottom or just on one side and a metal plate on the other? Thanks, Greg -- If, in your life, you attain the means to help; you incur the responsibility to act. |
248 days ago |
While I am obviously not one who has used magnets I plan on mortising them into the lid and carcass sides and covering them with oak veneer tape. I just rec my magnets yesterday so I will practice on some scrap. -- David, Dallas,Tx - golfing weather is nice but so is woodworking! |
237 days ago |
Divot, -- Saving barnwood from the scrapyards |
237 days ago |
Here’s the article on using magnets for a box pivot hinge: ” Pivot Hinge with Magnetic Appeal A dab of glue locked this top magnet in place in the lid, followed by a little mother-of-pearl disk to hide it. Since the bottom magnet protrudes slightly from the box, it nests in the lid hole to keep it perfectly aligned. The two magnets are strong enough to hold the lid in place while pivoting.”
Hope this helps – I have no idea where this little tidbit came from! Jim |
236 days ago |
In case anyone is interested, Radio shack sells pairs of rare earthmagnets for a couple bucks. I think they are for holding glass stereo cabnits closed, but they work well for lids. They say 1/8 diameter on the box, but are closer to 3/16. I usually by a pack or two to avoid the minimum buys that you will find on a website. -- Tom, Simsbury, CT |
| Forum | Topics |
Woodworking Skill Share
2937 |
3968 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
