Question: buying new motor for jointer....
Forum topic by Chuck E posted 03-19-2009 04:43 AM 15007 views 1 time favorited 17 replies Add to Favorites Watch
View Chuck E's profile
Chuck E
9 posts in 3787 days
03-19-2009 04:43 AM
Topic tags/keywords: jointer motor question
First, I’d like to say hey to everyone. I’ve been sort of a lurker here for a while now, but have been pretty busy trying to get my garage shop setup.
I recently bought a 6” craftsman jointer off a friend for 50 bucks. It was manufactured in 1976 and has a 1725 rpm 1/2 hp induction motor. It also has 3 blades. My friend told me that he only used it a few times but that the motor wasn’t very strong if he could remember right. I haven’t been able to test it out yet because it needs a stand to mount the motor, so I’m going to buy a new motor and design a jointer cabinet to attach it to with a chute to guide the chips to a dust port (I’ll post the project when it’s done).
I was thinking about picking up a 1 1/2 or 2 hp induction motor and was wondering if I should stay with the 1725 rpm or could I go with a 3450 rpm? The pulleys are 2” at the jointer and a 4” for the motor. This would equate the jointer going from 3450 rpm to 6900 rpm. Would this affect the safety or life of the jointer?
Any advice is appreciated. Thanks.
-- Chuck, Wisconsin
17 replies so far
View lew's profile
lew
12056 posts in 3752 days
#1 posted 03-19-2009 04:49 AM
Personal opinion, for safety, stay with the same RPM.
35120 posts in 4397 days
#2 posted 03-19-2009 04:52 AM
I might have the same jointer. I’ll try to look at what I have. I’m guessing it’s 3450. I’ve not used it in about 3 years.
View bendisplays's profile
bendisplays
40 posts in 3397 days
#3 posted 03-19-2009 06:56 AM
Chuck,
If you go with a 3450 rpm motor, then you will have to reduce it with the pully. Your jointer has been designed for a specific speed. Also the bearings are designed for a specific speed and may not be able to take a doubling of the rpm.
A good way to think of what you will be doing is to create a perspective. The diameter of a jointer can easily be 3” or more. So the velocity of a jointer running at 6900 rpm is the same as a 1/2” router running at 41400 rpm. Your jointer is also taking up to a 4-6” cut (or larger if you have a larger jointer).
I would up the horsepower of the motor so it wont bog down but I would stay at the same rpm (1725).
Ben
View marcb's profile
marcb
768 posts in 3670 days
#4 posted 03-19-2009 02:35 PM
Either way you go in terms of RPM replace the motor pulley to get the cutterhead speed to 4000RPM or so, keep it under 5000.
Also 1 1/2 HP is way overkill for a 6” jointer. I have a 3/4 HP on mine and can’t bog it down with 1/8” cuts across full face which is pretty deep for jointing.
View poroskywood's profile
poroskywood
618 posts in 3361 days
#5 posted 03-19-2009 02:47 PM
Keep the same RPM. Up-grade the Horse Power. HP=Happiness
-- There's many a slip betwixt a cup and a lip.--Scott
Chuck E
#6 posted 03-19-2009 03:24 PM
Thanks for the advice so far!
SO…. it appears all would be well if I stick to the same rpm and go with a 1 hp motor… I plan on using mostly hardwoods with it, so I don’t want to get stuck on the low end with the power. I’ve read that the hp rating isn’t always reliable, so I was thinking a little over-kill won’t hurt in this area.
-- Chuck, Wisconsin
marcb
#7 posted 03-19-2009 03:52 PM
It doesn’t matter which RPM’s you go with because you really need to get the cutter head into the 4500RPM range, which means buying a pulley of the right size.
If you get a 3450 RPM motor you need approximately 2.55” OD pulley (standard size, easy to find). Which can be had for about 5 bucks, pretty cheap way to ensure the machine works like it should.
Sticking with the slow speed at the cutter head that you have now means less force being applied to the cutting edge meaning more chatter. If you do stick with 1725 RPM motor you ill need a 3.15 OD pulley (closest standard size). buy online, get cast iron pulleys. Stay away from the diecast aluminum stuff found locally.
View Rick's profile
Rick
19 posts in 3732 days
#8 posted 03-29-2009 05:32 PM
I just bought a new Marathon motor through eBay for $15.00. The local motor store wanted $150 Mine was 3450 rpm, single phase, 1/2 HP. I upgraded to 1HP, same RPM. Hope that was right. Haven’t hooked it up yet. Question for you electricians: The original motor had a black & a white wire. This has blue, red, orange, black, white, yellow. The wiring diagram on the motor has 2 configs, 1 for “low power”, one for ‘high”. Assuming low power is 110V & high is 220, the setup for 110 is blue, red, orange connected together for ‘line 1’ , and blk, white yellow together for line 2. ! question is why were the blk, white orange wires twisted together from the factory. Should I go with the lo power config, & what about a ground wire? I emailed the company, haven’t gotten a response yet. Bet you LJs come up with an answer before they do.
Thanks folks
View David Freed's profile
David Freed
113 posts in 3664 days
#9 posted 03-29-2009 06:49 PM
“why were the blk, white orange wires twisted together from the factory?”
If the motor is reversible I would say it is wired in reverse of the diagram you are looking at. If not, I would guess it was wired for 220. Can you give more info about the motor? Is it reversible? Does it have a 220 diagram? Where does it say to fasten the incoming wires (110 & 220)?
As for the ground, you will need to supply that with the incoming wire. There should be a screw to fasten the ground wire to under the cover plate.
-- David, Southern Indiana
marcb
#10 posted 03-29-2009 08:36 PM
If all 6 leads are brought out the motor is reversible. If only 4 are it is sometimes depending on if the other 2 are start leads or not.
You can’t be sure what wire does what without confirmation with an ohm meter and some diligence. I don’t have the book with me that explains how to do the tests exactly. I can dig up more in Electrical Motor Repair if you need it. But I’m assuming Marathon will get back with you monday if you are still confused.
I would wire it the way it says, assuming this is a single phase capacitor start dual voltage motor low == 110. If it spins the wrong way reverse to the way it came wired.
View BlankMan's profile
BlankMan
1490 posts in 3349 days
#11 posted 03-29-2009 10:18 PM
Chuck,
It appears with the pulleys you mentioned the cutter head is already spinning at 3450. The fact that by the pulleys you’re increasing the speed you’re also reducing the HP/torque, probably why your friend said it was probably a little weak at cutting. If you increase the horsepower and increase the RPM then use equal diameter pulleys you’ll stay at the same cutterhead RPM but you’ll see the rated HP/torque at the cutterhead, now you’re not.
I’d consider upping the motor speed then adjusting the pulleys so that you stay within the rated RPM of the cutterhead and bearings. Faster cutterhead speed means more cuts per minute thus a smoother finish. The cutterhead on my DJ-20 spins at 5500 RPM, 16,500 cuts/minute.
You’ll have to do some digging to get the specifications of the cutterhead and bearings if that’s even possible. If the bearings maximum RPM is less then the cutterhead you might be able to then replace the bearings with higher RPM bearings.
It’ll cost to do that so you have to decide if it’s worth it to you. Worst case you could also replace the cutterhead and bearings with a set rated at a higher RPM. But like I said it will cost so it’s up to you if it’s worth it.
-- -Curt, Milwaukee, WI
Chuck E
#12 posted 04-19-2009 07:11 PM
Thanks to everyone for the thoughtful replys. I guess it’s time to look for a motor and bearings now. :)
-- Chuck, Wisconsin
BlankMan
#13 posted 04-19-2009 07:33 PM
Chuck, since I see you’re from Wisconsin, Mill’s Fleet Farm or Blain’s Farm & Fleet might be a good place to look for a motor if you have any near you. I picked up a 1HP Marathon motor for my drill press a bunch of years back but don’t remember what it cost.
Again, based on you’re locale, I was at the Northern Tool store in West Allis this past week and they had a 1HP 3450 RPM Leeson motor on the clearance shelf for $129. It might be gone because yesterday they had their big 10% off store sale and when I stopped there the place was packed and I think I saw it on one of their outdoor parking lot table displays. If that’s too far for you but you’d consider driving there for it I’d offer to stop and see if it’s still there before you did if you want.
Chuck E
#14 posted 04-19-2009 07:42 PM
Curt, Thanks for the advice. There’s a Fleet Farm and Farm and Fleet near by. I’m near Madison, so Northern would be a road trip, but based on what I see at the other two, that might still be a savings.
Btw, your advice on the motor/bearings was excellent. I plan on doubling the rpm and upping the hp to around 1hp with a new cutter head, bearings, and pulleys. The jointer is in good condition and I got it cheap. Since I have to build a cabinet for it, I might as well do this so I can get some good use out of it.
-- Chuck, Wisconsin
BlankMan
#15 posted 04-19-2009 07:46 PM
Thanks. Chuck from Madison? Would that be COP by chance?
