MDF shooting boards?
« back to Hand Tools forum
Forum topic by Brett posted 01-12-2015 10:49 PM 3332 views 0 times favorited 12 replies Add to Favorites Watch
View Brett's profile
Brett
661 posts in 2861 days
01-12-2015 10:49 PM
Has anyone here made a shooting board from MDF? I’ve come across several sources that recommend MDF for the base (but hardwood for the stops), but I wonder how well the edge of the MDF stands up to the plane and whether the MDF itself causes excessive wear on the plane.
-- More tools, fewer machines.
12 replies so far
View Tim's profile
Tim
3812 posts in 2139 days
#1 posted 01-13-2015 12:41 AM
Paul Sellers in his video mentioned he uses a plywood board that came with a bonded “hardened surface”. The surface (a type of plastic I assume) reduces the friction. MDF would work for flatness, but maybe someone can recommend a specific product with a surface like Paul recommends.
Here’s the video btw:
https://www.youtube.com/watch?v=-Ypbvcxb-8M
View SteveHas's profile
SteveHas
11 posts in 1777 days
#2 posted 01-13-2015 12:49 AM
I would take a look at a video by Rob Cosman.
He uses an mdf shooting board and the way it is designed only the “cheeks” of the plane run on the mdf. The cutter never touches it, plus the fence at 90 or what ever angle the shooting board is designed for never contacts the blade neither. I use it on almost any task in my shop. I always finish with the shooting board even after my diablo blade cuts it at the table saw. Nothing is cleaner than shooting with a nice sharp blade.
View Derek Cohen's profile
Derek Cohen
394 posts in 4146 days
#3 posted 01-13-2015 02:55 PM
As long as you (1) seal the MDF to prevent the incursion of moisture, and (2) add a hardwood edge, then you can use MDF …
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View Bill White's profile
Bill White
5108 posts in 4138 days
#4 posted 01-13-2015 03:09 PM
I made mine from Extera brand exterior grade mdf. More dense and stable (and heavy).
Sanded, shellac, waxed, done.
Bill
-- bill@magraphics.us
Bill White
#5 posted 01-13-2015 03:09 PM
Bill
Bill White
#6 posted 01-13-2015 03:11 PM
Dang double post. Sorry.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1753 days
#7 posted 01-16-2015 02:47 AM
Here s the video btw:
- Tim
Formica is the hard plastic surface
View ksSlim's profile
ksSlim
1286 posts in 3068 days
#8 posted 01-16-2015 08:35 AM
Mine is Melamine over Baltic ply piece.
Hardwood stops. If you apply Melamine to Baltic. Do both surfaces DAMHIK.
Even good ply can warp if not properly stored.
My last one has been in use for over 20 yrs.
-- Sawdust and shavings are therapeutic
View Sylvain's profile
Sylvain
748 posts in 2677 days
#9 posted 01-18-2015 04:09 PM
P. Sellers uses a plywood made for concrete formwork.
the faces are covered with a slippery plastic which looks like bakelite.
Available in all “home improvement” shops in Belgium.
Not so many wooden houses here.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View dbeck's profile
dbeck
65 posts in 537 days
#10 posted 06-05-2017 03:58 PM
When you speak of the plastic type surfaces are you referring to the ramp the plane rides on? You wouldnt want the board that your piece sits on to be slippery would you? I have a dissability so it may just be me but holding the piece solid so it doesnt slip would be tough on slippery plastic, wouldnt it? I went so far as to use psa sand paper on mine. I hope this doesnt sound like im stating fact i am a newbie and just learning.
View TheFridge's profile
TheFridge
10515 posts in 1664 days
#11 posted 06-05-2017 04:43 PM
I use ply but I put strips of uhmw tape on the edge of the board and the keeper strip on the right side of mine. Works like a champ for me. Just another option. I almost have a roll of 3/4 uhmw pe tape floating around the shop for different needs.
View mitch_56's profile
mitch_56
20 posts in 651 days
#12 posted 06-06-2017 01:02 AM
For the Paul Sellers material, there are a number of flavors of plywood which come with melamine on one side.
As for a better, more water-resistant MDF, Medex was the trade name…it’s the MDF variant that the countertops are made out of at places like Starbucks. A bit better physical properties over normal MDF, and much improved moisture resistance.
However, now I don’t see Medex anymore around here, and there’s an upgraded replacement, IIRC it’s called Apex MR50. They also make an Apex FR which has enhanced fire resistance.
