Table overhang at end of testle
Forum topic by jimmy J posted 01-12-2015 06:17 PM 971 views 0 times favorited 5 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2254 days
01-12-2015 06:17 PM
I have a 74” table top build and now moving on to the trestle base. The Maple top is 1.5” thick, and 36 wide. I’m trying to figure out what the max overhang could be for the end of the table. I have long legs so don’t want to hit the support under the table which argues for a large overhang. , I’m also 250lbs, and don’t want to have to worry about the table tilting if I lean on it, which argues for a short overhang.
Any good rules of thumb to work with?
5 replies so far
View pjones46's profile
pjones46
997 posts in 2518 days
#1 posted 01-13-2015 01:52 AM
The problem is more so the choice of trestle leg with your project. If Leg room is the major concern change to a standard four leg table or know that you are going to have to sit on the sides of the table. If you push the trestle too far in from the end, ascetically, it may look strange, however if that is not a concern set the top up on some milk cartons 29”-30” high and see what works for you.
-- Respectfully, Paul
jimmy J
#2 posted 01-13-2015 02:35 AM
Thanks. I’ve already made the top with a curve on the long edges, modeled after the Ashi table design several other jocks have made (originally by Daniel Chaffin) . Don’t think it would look good with legs on the corners. Kind of needs a trestle, or a shaker look.
pjones46
#3 posted 01-13-2015 03:27 AM
Definitely then set it up on milk cartons to test out what fits you. Good luck, it should look awsome.
View Patch2020's profile
Patch2020
97 posts in 1116 days
#4 posted 01-13-2015 04:31 PM
With a 74” top and not wanting to use legs, I would use a pedestal. I worked in my Dad’s furniture shop from the time I was 7 and his main business was wholesaling tables. A 10” pedestal with 12” to 14 ” feet should be good. To help with the concern over leaning on the end of the table, instead of attaching the bottom plate directly to the braces that run the length of the table use cross brace placed 19” outside to outside and attach the plate to them. We built thousands of tables and never had any problems with them pressing down.
-- Patch2020, Tennessee
View AlaskaGuy's profile
AlaskaGuy
3797 posts in 2184 days
#5 posted 01-13-2015 07:51 PM
Like patch2020 said 12-14 inches of knee room.
You could also go to a furniture store and see commercial guys do.
