Question about jointer planes
« back to Hand Tools forum
Forum topic by Joel_B posted 01-12-2015 05:28 PM 1065 views 0 times favorited 8 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
347 posts in 1500 days
01-12-2015 05:28 PM
I have been looking at Stanley no 7 jointer planes on ebay and some have a corrugated bottom.
Is there any difference between corrugated and smooth in actual use?
I am thinking corrugated might have less friction on a large flat surface.
One thing I might use it for is jointing very thin edges (about 5mm thick) for guitar bodies and I am worried that the edges on the corrugated bottom might be a detriment by catching the edge of the thin wood.
Edit: Paul Seller’s doesn’t like them:
https://paulsellers.com/2012/10/questions-answered-on-corrugated-soles/
Thanks
-- Joel, Encinitas, CA
8 replies so far
View sikrap's profile
sikrap
1121 posts in 3478 days
#1 posted 01-12-2015 07:49 PM
My opinion is that there is no difference in use other than the corrugations catching when edge jointing. Also, if you need/want to flatten the sole, the corrugated is a little easier/quicker because you’re removing less metal.
-- Dave, Colonie, NY
View BubbaIBA's profile
BubbaIBA
387 posts in 2496 days
#2 posted 01-12-2015 09:14 PM
I am thinking corrugated might have less friction on a large flat surface. One thing I might use it for is jointing very thin edges (about 5mm thick) for guitar bodies and I am worried that the edges on the corrugated bottom might be a detriment by catching the edge of the thin wood.
Edit: Paul Seller s doesn t like them:
Thanks
- Joel_B
If one of your intended uses is jointing edges a 7C would not be a plane I would expect to work well. You should look for a #8 or #7 with out the “C”. BTW, a little wax takes care of the friction issue.
ken
View OSU55's profile
OSU55
1834 posts in 2108 days
#3 posted 01-12-2015 09:47 PM
The corrugated soles were another Stanley marketing gimmick, supposedly to reduce friction. They don’t (a little wax as previously mentioned does that), and they limit the particular tool because of edge catches. The only “C” I have is a #2C I inherited from my dad, and it’s the only one I will have.
View DanielS's profile
DanielS
123 posts in 2056 days
#4 posted 01-12-2015 09:49 PM
I have a 7C and a smooth sole 8. They both work well for jointing. I use the one that is sharpest first, so they’re used interchangeably. The thinnest stock I’ve used either on is 3/8. Anthing I’ve done as thin as 5 mm was short, so I used a smaller plane.
-- Daniel S
View MikeUT's profile
MikeUT
171 posts in 1478 days
#5 posted 01-12-2015 11:04 PM
I have a No 7 and a 608C. I reach for the larger plane 9 times out of 10 but that’s because its a bedrock and I also like the extra mass. I do have a few number 5’s both with and without corrugations and personally I can’t tell much of a difference. The ‘C’ doesn’t play in much to my buying decision. I can see your concern about the plane being wobbly on the top of a thin surface but on a guitar top you’d have that problem either way. I haven’t made a guitar but if I did I would definitely use a shooting board. Here is a pretty good demonstration. https://www.youtube.com/watch?v=2xOJAjdGZUY
View Don W's profile
Don W
18938 posts in 2687 days
#6 posted 01-14-2015 01:00 AM
There is not much difference. I find a C tends to pinch my finger in the groove slightly if jointing thin stock, but I’m the only one I’ve ever heard that from and its nothing that would stop me from using one.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1694 days
#7 posted 01-16-2015 02:26 AM
Some had a oiler in the handle to make planing easier.
Don W
#8 posted 01-16-2015 02:35 AM
If you find one with the oiler, hang onto it well.
