May I put thinned Poly over Arm-R-Seal?
Forum topic by Keith Kelly posted 01-12-2015 02:54 AM 1576 views 0 times favorited 5 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
263 posts in 1592 days
01-12-2015 02:54 AM
Topic tags/keywords: question
Problem: I don’t have enough Arm-R-Seal for another coat I need to make.
How I got into this mess: Before my last coat of Arm-R-Seal, I buffed with 0000 steel wool. However, I only wiped it off by hand (gasp!) before applying the Arm-R-Seal. When applying the finish, there were steel wool nubs in my finish. Once I realized this, I quickly took a rag soaked in MS and wiped the table. It wasn’t tacky, but there is certainly unevenness in the finish now. (not hard lines, but just some places that look like they took more of the last coat than the rest)
The amount of Arm-R-Seal I have left is about 1 tablespoon. (yikes!)
Once this becomes un-tacky, may I put a 50/50 mix of Polyurethane/MS over the top?
Unfortunately, time is a huge factor here.
You can soooooorrrta see what I’m talking about in this picture. The walnut on the lower right is certainly glossier/deeper than the walnut in the reflection of the left light.
-- Keith - Bolivar, Missouri,
5 replies so far
View bobasaurus's profile
3391 posts in 3113 days
#1 posted 01-12-2015 03:22 AM
Oil-based poly would probably work. Since they are both oil-based urethane resins, they should bond to each other without trouble. Maybe try it on the underside or a back edge first.
I keep a big magnet around for pulling off steel wool dust. I kind of hate the dust, but nothing works better than steel wool between coats.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View waho6o9's profile
8125 posts in 2506 days
#2 posted 01-12-2015 03:29 AM
How about bronze wool?
Keith Kelly
#3 posted 01-12-2015 03:30 AM
Alright thanks. Yeah it is the typical Minwax oil based polyurethane. I wish I had used steel wool in between previous coats, as I would have learned my lesson by now and I definitely think it worked better.
I’m guessing your magnet has a relatively large surface area then, or you have a lot of patience.
Keith Kelly
#4 posted 01-12-2015 02:51 PM
Alrighty, that seemed like it worked very well! In fact, I’m thinking that in the future, I may never ever use Arm-R-Seal again. The Poly/MS blend was far easier to apply on such a large area than the Arm-R-Seal. At this point, I’m convinced that for wiping large surfaces, Poly/MS has Arm-R-Seal beat by miles (as far as the application process goes). It flows & levels so nice.
Thanks for verifying.
View bondogaposis's profile
4629 posts in 2280 days
#5 posted 01-12-2015 02:58 PM
I have given up on steel wool entirely and now use 400 grit sandpaper between coats. Try it, you’ll like it.
-- Bondo Gaposis
