Beadboard support for hooks
Forum topic by tazboy posted 01-12-2015 12:19 AM 918 views 0 times favorited 3 replies Add to Favorites Watch
View tazboy's profile
tazboy
30 posts in 1677 days
01-12-2015 12:19 AM
Topic tags/keywords: beadboard plywood coat
Hello all,
I want to make a coat hanger area for my entryway. The issue I have is that I were to just attach beadboard to the wall then I would have an issue with easily screwing things into the beadboard, like hooks, or adding a support structure like benches and shelves. I was thinking about attaching plywood to the drywall and then putting the beadboard on that. I’m just not sure how thick the plywood should be.
Would 1/4” be sufficient?
Is 11/32 sheathing ok?
Is 7/32 underlayment ok?
My initial thought is that 1/2” plywood would be needed to have a sufficient base to work with.
3 replies so far
View RockyTopScott's profile
RockyTopScott
1186 posts in 3386 days
#1 posted 01-12-2015 01:16 AM
I use the 3/4 beadboard planks for that sort of thing.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
tazboy
#2 posted 01-12-2015 02:50 AM
Can I install the 3/4” beadboard without gluing it to the drywall? I was thinking about screwing 1/2” plywood to the drywall and then gluing/nailing the beadboard to that. That way I don’t ruin the drywall if I want to change things years later.
tazboy
#3 posted 01-19-2015 02:11 PM
I’ll go with the 1/2” or 3/4” plywood with beadboard attached to that.
