MDF for homemade Moxon Vise!!!!
Forum topic by EdsCustomWoodCrafts posted 01-10-2015 07:54 PM 1961 views 0 times favorited 18 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
868 posts in 1583 days
01-10-2015 07:54 PM
I saw a plan for a homemade Moxon vise using pipe clamps and I wouldn’t ususlly Ask this type of question because MDF might not be strong enough, but I have a ton of MDF left and I would love to make this without spending much..
Or should I just go and get 1/2” PLY!!!!!!
Here is the plan im looking at
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
18 replies so far
View greg48's profile
greg48
610 posts in 2997 days
#1 posted 01-10-2015 08:05 PM
Give it a try w/ MDF, if it doesn’t work for you then you can always rebuild it with ply
-- Greg, No. Cal. - "Gaudete in Domino Semper"
EdsCustomWoodCrafts
#2 posted 01-10-2015 08:32 PM
Give it a try w/ MDF, if it doesn t work for you then you can always rebuild it with ply
- greg48
Thanks Greg48…. Will do … I don’t own any pipe clamps, can you recommend any for this project!!! I’m thinking a 12” opening ???
View TheGreatJon's profile
TheGreatJon
340 posts in 1473 days
#3 posted 01-10-2015 08:45 PM
You can get pipe clamp fittings from harbor freight for something like $9/pair. Then get whatever length of pipe you want from Lowes/HD. Be sure to have them cut it for you and thread the ends (they do it for free).
-- This is not the signature line you are looking for.
View NoThanks's profile
NoThanks
798 posts in 1768 days
#4 posted 01-10-2015 09:38 PM
Don’t waste your time with mdf. It splits, will never be strong enough.
-- Because I'm gone, that's why!
View poopiekat's profile
poopiekat
4408 posts in 3974 days
#5 posted 01-10-2015 10:30 PM
I was amused at “Jay’s Custom Creations” for asking for payment for a plan idea that has been done perhaps a thousand times over by others.
View paxorion's profile
paxorion
1107 posts in 2285 days
#6 posted 01-10-2015 10:30 PM
Don t waste your time with mdf. It splits, will never be strong enough.
- Iwud4u
Yes, safe the MDF for other jigs
-- paxorion
View Radu's profile
Radu
330 posts in 3283 days
#7 posted 01-10-2015 11:11 PM
I was amused at “Jay s Custom Creations” for asking for payment for a plan idea that has been done perhaps a thousand times over by others.
- poopiekat
Last I checked on Jay’s site (30 sec ago) the plan for the Moxon style vise was in the free section.
So, if you do not have anything nice to say, better shut up.
View PhillipRCW's profile
PhillipRCW
511 posts in 1504 days
#8 posted 01-10-2015 11:21 PM
Last I checked on Jay s site (30 sec ago) the plan for the Moxon style vise was in the free section.
- Radu
Apparently someone is having a rough day. Need a hug?
-- Phillip- Measure twice, cut onc.... Hey look, it's rustic.
View TheDane's profile
TheDane
5575 posts in 3902 days
#9 posted 01-10-2015 11:23 PM
If you click the link in Ed’s post, it takes you directly to Jay’s site so you can open or save the plan.
He is not charging for it.
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#10 posted 01-10-2015 11:51 PM
The plans are free. Striaght MDF might not hold up in the long run. MDF has good compression strength but not good tensile strength. I bet if you backed the MDF w/ plywood it would hold up pretty well.
-- Bondo Gaposis
NoThanks
#11 posted 01-11-2015 12:38 AM
^I agree that you probably could make the mdf work, but why?
The amount of material needed is so minimal, there is no reason not to use a better material.
poopiekat
#12 posted 01-11-2015 12:38 AM
Radu:
Ahem, well if you bothered to look further, he is soliciting contributions. But if you want to get something for free from him, you have my blessings.
Odd, how your advice was worded, about not having nice things to say.
EdWood:
I’d encourage you to look for some solid hardwood for your movable jaw; it doesn’t have to be pretty but I’d be afraid of plywood flexing and denting your work.
http://lumberjocks.com/projects/46992
View kwolfe's profile
kwolfe
108 posts in 1804 days
#13 posted 01-11-2015 01:04 AM
If you double up the mdf, it will probably be plenty strong. 1.5” of mdf over a small span is pretty darn stiff
EdsCustomWoodCrafts
#14 posted 01-11-2015 01:07 AM
- kwolfe
I’m actually tripling it with (2 )3/4” and (1) 1/2” board
View ChuckC's profile
ChuckC
843 posts in 3174 days
#15 posted 01-11-2015 04:37 AM
The MDF will probably work but the Moxon requires so little wood I wouldn’t even bother. I don’t get why it has to slide too? I just clamp mine the the bench so the back jaw just hangs off the edge. I think the pipe clamps are going to be annoying to adjust too. You are going to have to hold your stock and at the same time tighten the clamps. The weight of the front jaw is going to pull down on the clamps and I have a feeling it’ll get old soon.
I made a Moxen last winter and originally buried a 1/2” nut in the back jaw (on the back) and then used 1/2” acme rod to hold and tighten the front jaw. What a pain! the weight of the front jaw (thick walnut) pulled down on the screws and it made tighten them very hard. I dumped all of the hardware, saved the wood, and bought the Benchcrafted Moxen hardware. What a difference! The thread bolts to the back jaw which holds the front jaw up. The wheels in front are very heavy and with just a spin they lcm the wood in place.
