Router Base Plates
Forum topic by CanadaJeff posted 03-15-2009 05:57 PM 924 views 0 times favorited 5 replies Add to Favorites Watch
View CanadaJeff's profile
207 posts in 3539 days
03-15-2009 05:57 PM
Hi everyone,
I am finally starting to design and build my own router table. I was going to pickup a piece of acrylic to make a router base plate, however I’m not entirely sure how thick I should get.
Any thoughts?
5 replies so far
View interpim's profile
1170 posts in 3387 days
#1 posted 03-15-2009 06:19 PM
I used 1/2” UHMW Plastic, and it is holding up my 3.5 HP craftsman router np.
-- San Diego, CA
View Francisco Luna's profile
Francisco Luna
943 posts in 3322 days
#2 posted 03-15-2009 06:23 PM
I made mine with clear plexiglass about 3/8” (9.5 mm) thick, keep in mind the wieight of your router.
-- Nature is my manifestation of God. I go to nature every day for inspiration in the day's work. I follow in building the principles which nature has used in its domain" Frank Lloyd Wright
View DannyBoy's profile
521 posts in 3794 days
#3 posted 03-15-2009 06:38 PM
I’ve not made one yet, but I have read that some don’t do inserts at all due to the amount that most materials will sink and bend with the weight. You may want to just design the table so that you have plenty of room underneath to work.
-- He said wood...
View lew's profile
11982 posts in 3684 days
#4 posted 03-15-2009 07:23 PM
Just a thought, you will probably need to get new mounting screws- their length may need to be considered as part of your choice for plastic thickness.
View marcb's profile
768 posts in 3602 days
#5 posted 03-15-2009 08:49 PM
1/4” Aluminum plate.
You can work it with woodworking tools. I made mine with a drill press some router bits and a hand file. Nice and flat and won’t sag not matter what.
With above the table bit changes in the Freud I wanted to avoid anything thicker than 1/4” it barely gets high enough for 1/4” plate let alone anything thicker.
