Closing the Gap
Forum topic by Robert Herring posted 254 days ago 196 views 0 times favorited 8 replies Add to Favorites Watch
View Robert Herring's profile
Robert Herring
26 posts in 273 days
254 days ago
This is probably an easy do, but I can’t think today. Could someone please tell me how to the gap between the two pieces?
Thanks,
Robert Herring
-- Robert M. Herring
View drgoodwood's profile
drgoodwood
381 posts in 1021 days
254 days ago
Two pieces of what?
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
Robert Herring
254 days ago
I’m sorry, I’m trying to upload a picture, but to no avail. I have two pieces of wood that i’m trying to match the angles on. It’s the frontofaboat and they come together at a point. I have a gag at the bottom of the angle and I’m trying to figure out how to close the gap and match them up
View Toolz's profile (online now)
Toolz
307 posts in 636 days
254 days ago
I’m not sure without seeing a photo, but I would use a hand plane (block) starting at the widest part of the gap and slice minutes amounts off each piece testing after each pass. I think this is called “sneaking up on the angle” Do a search here re:” miters” or “closing the gap on a miter”. Hope this helps.
-- Growing older but not up!
Robert Herring
254 days ago
I’ll try to get a picture up
View 8iowa's profile
8iowa
592 posts in 654 days
254 days ago
A picture would be helpful. I would probably use my 12” disk sander after carefully setting the angle on the miter gauge with a precision protractor
Robert Herring
254 days ago
Robert Herring
254 days ago
Thanks Ralph. Here’s what I’m facing.
View alanealane's profile
alanealane
174 posts in 784 days
254 days ago
If you can afford to cut more material off, stack both pieces together carefully with double-stick tape in between them. Make sure they’re exactly lined up with one another. Set up your miter saw to the angle you need, and cut them both at once.
I think this will get both angles to be “matched”.
-- Lane Custom Guitars and Basses
