super glu vs wood glu
« back to Joinery forum
Forum topic by JerryLH posted 01-09-2015 04:58 PM 835 views 0 times favorited 3 replies Add to Favorites Watch
View JerryLH's profile
JerryLH
134 posts in 1334 days
01-09-2015 04:58 PM
Strength, holding power, small projects—CA glues are fast and, for me, easier to use than wood glue for small cigar box size projects. Of course we know that easier is not necessarily better. In my priority list better is #1 and easier #2. Having said that what would be your thoughts as to better? Thanks for any input.
-- Develop your character -- for it becomes your destiny. Jerry - Mannford, Ok
3 replies so far
View jacksteel's profile
jacksteel
21 posts in 1255 days
#1 posted 01-10-2015 04:37 PM
I was reading a thread about using super glue vs. yellow wood glue but cant find it now. Most said they used super glue over yellow glue mainly for speed.
I wanted to let you know when I use to own and run a silkscreen business I stretched and made my own wood screens with the Monofilament screen meshes.
The mesh was adhered to the wood or metal screen frames using what they called “RhinoMite Two-Part Frame & Mesh Adhesive” I would guess there are other brand names.
Its is basically supper glue with a spray on activator that instantly cures the wood glue.
http://estore.lawsonsp.com/rhino-mite-two-part-frame-and-mesh-adhesive.aspx
No waiting at all. Instant strong joint and with the tension and shear force required for the application i was using it for it never failed EVER!
I never recall the glue or the activator ever staining. it was alway clear like it was never there
Might give it a try. I have not used it for wood working as I am a die hard tight bond 2 user
-- In a time of universal deceit (today)- telling the truth is a revolutionary act. George Orwell
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#2 posted 01-10-2015 05:17 PM
For regular joinery I’d go with regular. I’d think it would fill gaps better than CA glues but could be wrong. I’m just speculating but I think regular glue has a higher shear strength while super glue had a higher tensile strength. Or something like that.
JerryLH
#3 posted 01-11-2015 12:14 AM
Thanks to all – I appreciate it.
