grooved ends when planing..
Forum topic by woodboxman posted 488 days ago 183 views 0 times favorited 4 replies Add to Favorites
View woodboxman's profile
woodboxman
30 posts in 498 days
488 days ago
Hi all, i just put new blades in my craftsman 12 inch planer that i just got not too long ago. I don’t have a manual for this machine.The boards kinda jump when they come out and it grooves the last 2 1/2 inches of the board.How do i adjust this out of it.There are holes in the base to stick a screwdriver and adjust the metal rollers and i can’t turn them, anyone with this machine know how to do this?
Thanks for the help
-- Roy "Woodboxman" Coos Bay, Oregon
View edp's profile
edp
102 posts in 488 days
487 days ago
I’m not familiar with your machine but I believe that the problem you are referring to is called SNIPE. One surefire contributor to snipe is an outfeed table that is out of adjustment. To check this, you could open your machine to the maximum (unplugged of course) and use a level or other straight edge to verify that the lower rollers in the machine (or the slide deck if no rollers) and the infeed and outfeed tables are sharing the same line and do not sag under the weight of the outcoming board. There’s a better than even chance that a small adjustment here could eliminate your problem.
Ed
-- Come on in, the beer is cold and the wood is dry. www.crookedlittletree.com
View mot's profile
mot
4851 posts in 564 days
487 days ago
Yup, that’s snipe. It is caused by a few things, but generally can be fixed with outfeed support of the board. a little sag when it comes off the front roller causes the end of the board to blip up into the cutter. Also, if your blades are a little taller than the original set, the events that cause snipe are even more magnified. Check the height of the blades with a good caliper. You may have to adjust the gibbs that hold the blade to compensate. I’d try the outfeed support first though.
View Drew1House's profile
Drew1House
421 posts in 616 days
487 days ago
You could also push another sacrificial scrap through on a sled behing the board you are plaining. It is a work around but helps me when in a hurry…
Drew
-- Drew, Pleasant Grove, Utah
woodboxman
487 days ago
Thanks, i did have to adjust the gibbs when i first installed the new blades but i do think the out feed is out of adjustment, which is causing the problem..
Bookmark And Share This Page
