| Forum topic by Primitiques | posted 258 days ago | 137 views | 0 times favorited | 2 replies | ![]() |
258 days ago |
257 days ago |
I’d use a long mortise and tenon, pegged in the center and at least two other places, depending on the table width. - The end should be slightly longer than the main width, in a season where the table is widest. The end should always be slightly proud of the main section To make the joint, I’d rout the mortise first, centered in over-thick stock. Next, I’d rout the tenon into the ends of the top from alternate sides, leaving it fat. I’d sneak up on the fit with a shoulder plane. If you don’t have a shoulder plane, you can sneak up with the router. Don’t worry if you’re a tad off center,as the end part is still fat. Last, I’d properly thickness the end. It’s common for the end to be left slightly thicker than the main section. Play around with some MDF to get the feel for the different operations if you’re uncomfortable. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
257 days ago |
i do a glue up just as if it was not going to get a bread board end.. then just a touch of glue in the center.. and dowels.. the dowel holes on the mortise end are elongated.. that let the panel expand.. just make sure it has room by making the tennon stop short of the mortise.. when you test fit the ends, you should be able to slide then left or right at least 1/2 an inch.. -- It's not a sickness, i can stop buying tools anytime. |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2391 |
LumberJocks.com Site Feedback
524 |
