| Forum topic by Elvin | posted 259 days ago | 370 views | 0 times favorited | 9 replies | ![]() |
259 days ago |
I completed my mantel and surround and then painted it with water base primer and semi gloss white finish. Well the paint I used was Sherman Williams and after the first coat it wasn’t blending and left a lot of brush marks and skipping. I gave the project a light sanding and applied a second coat and again had the same problem. I called the paint store and they told me the paint has a very fast drying time and once you put it on don’t try to blend it. They also stated that you can only put it on in 2-4 inch sections at a time. Well now the project is in really bad shape and I feel I just want to remove this paint and lacquer spray a new primer and semi gloss finish. Any suggestions on removing the newly applied paint? Should I sand it to bare wood or get some paint stripper? I am really at a loss and as you can tell I am not a professional finisher or at this stage of the game any type of finisher because I am not finished. -- Elvin, Southern California, "How great would life be if we lived a little of it everyday" |
