Is there a reason this joint won't work?
Forum topic by daddywoofdawg posted 01-09-2015 04:05 AM 1031 views 0 times favorited 10 replies Add to Favorites Watch
View daddywoofdawg's profile
1028 posts in 1505 days
01-09-2015 04:05 AM
Topic tags/keywords: joining
I want to glue up 3 2×4” boards to make some legs and stretchers, Is there a reason this joint won’t work? as opposed to glue up then cut out.
10 replies so far
View ShaneA's profile
6894 posts in 2529 days
#1 posted 01-09-2015 04:09 AM
It will work, plus you should be able to get a nice fit with clean shoulders. I am assuming your drawing is not scale and the tenon will fit the mortise…of course.
View bandit571's profile
19476 posts in 2614 days
#2 posted 01-09-2015 04:12 AM
Problem would be in keeping the parts lined up during the glue up. Maybe add a tenon sized chunk, wrapped in wax paper or plastic tape. When the glue is dried, you can then just knock the plug out.
View oltexasboy1's profile
250 posts in 1635 days
#3 posted 01-10-2015 02:56 AM
That’s the way I made the legs and stretchers for my bench, worked for me.
-- "The pursuit of perfection often yields excellence"
View kdc68's profile
2643 posts in 2207 days
#4 posted 01-10-2015 04:00 AM
That’ll work…...and +1 for bandit’s suggestion…
-- Measure "at least" twice and cut once
#5 posted 01-10-2015 06:54 AM
Ya I was planning on doing it bandit’s way.So how come you never see anyone doing it that way? seems everyone glues then cuts and chisels.
#6 posted 01-10-2015 07:00 AM
Can control how tight the joint is.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3643 days
#7 posted 01-10-2015 07:12 AM
I’ve seen a number of bench builds using this approach. Doesn’t Paul Sellers do something like this on one of his builds?
View crank49's profile
4030 posts in 2901 days
#8 posted 01-10-2015 07:23 AM
Built my bench out of laminations like that.
Mine was all built out of 3/4” plywoood layered to be 4×4 legs, 2 1/4×6 stretchers, tenons are 3/4×6 x 4 long.
The concept was exactly the same though. And i used the wax paper wrap on a dummy tenon during glue-up.
All this worked perfectly. I love my bench. Been using it since 2008.
Daddywoofdawg, there are Youtube videos of building the “Roubo” style double mortise and tennon using the same idea and many examples of the 2×4 layup also.
View AlaskaGuy's profile
3970 posts in 2239 days
#9 posted 01-10-2015 08:46 AM
It will work. Bandit’s idea is good. Even if the tenon is a little small or large you can trim it down or build it up a little like any ill fitting M&T joint.
View JohnChung's profile
401 posts in 2005 days
#10 posted 01-10-2015 08:58 AM
This joint has been used before. The reason it is not that popular is the glue used to hold the wood together. Ppl prefer to use a single piece and cut out the tenon or mortise.
