Pine Boards Leak Sap
Forum topic by phonewired posted 07-24-2007 05:21 AM 16901 views 0 times favorited 19 replies Add to Favorites Watch
View phonewired's profile
phonewired
43 posts in 4267 days
07-24-2007 05:21 AM
Hi, I have been building projects with new pine lumber. Sometimes the boards leak sap. I have used Zinseer sanding sealer and that seems to help hold in the sap. I tried to take a shortcut and not use sanding sealer. The cabinet that I had sold leaked so bad on the door I had to take it back and replace it. I cant afford to have this happen again. I have heard that pine is noted for this. I guess I need to move to another type of lumber that wont leak sap. I build primitive furniture and pine gives me a specific look that I can sell. Would basswood work for large projects like cabinets and benches? Or is there a sure way to hold in sap. Thank you.
-- Noel, Iowa www.primitivefurnituresales.com
19 replies so far
View Dorje's profile
Dorje
1763 posts in 4170 days
#1 posted 07-24-2007 07:33 AM
I think that clear dewaxed shellac is used for just that purpose… The sanding sealer has a lot of driers in it, and it’s thinner than shellac.
Basswood may be a bit soft, but you could certainly try it. What about poplar?
phonewired
#2 posted 07-24-2007 01:51 PM
Would you sugest using the clear dewaxed shellac as a final coat to old this in or as a fist coat sealer instead of the sanding sealer? I like poplar for my painted projects. It’s great. I have a problem with iti weighing more. I am going to be maileng items and want to keep the pounds as low as possible also. Basswood will work well for small items. Light weight wood and easy to form. If the dewaxed shellac holds in the sap my problems are over.What about adding shellac flakes to my Zinseer sealer that I already have? Thank you, Noel.
Dorje
#3 posted 07-24-2007 05:59 PM
I was thinking that you could try the shellac instead of the sanding sealer. You could certainly try adding the flakes to the sanding sealer if it’s an alcohol (denatured) based product. You may need to allow more shellac to soak in around and on the knots to get better results (i.e., less pitch coming out), but this is just a guess – though it makes sense to me. Let us know how you fare.
View Bill's profile
Bill
2579 posts in 4334 days
#4 posted 07-24-2007 06:58 PM
I was going to suggest going to poplar, but it sounds like you have covered that already. Instead, I would second Dorje’s idea of using the shellac instead of the sanding sealer. Or, you could use the shellac on top of the sanding sealer for extra coats. The more coats the less likely anything would leak.
I am guessing that it is the knots that are leaking the sap, not the main board itself. Since you probably want to keep the knots for looks, maybe you can try what some of the wood turners do on knots. When they encounter a knot in a piece, they will soak it in CA glue (cynoacrylate – also known as crazy glue). There are several thicknesses of this glue, and I would think one would work for your needs. Cover the knot with the glue, let it dry, and then sand as needed. I would say do your sanding first, add the glue, and then do a finish sanding to smooth over the glue.
The glue route sounds like a lot of work if there are lots of knots, so the shellac may be the way to go. I have not tried it, but I have read that you can apply varnish over shellac after it is dry. That will allow you to keep a varnish finish if that is what you do to your work.
View Drew1House's profile
Drew1House
425 posts in 4261 days
#5 posted 07-24-2007 08:01 PM
Poplar is common and normal in the eastern US… I have no experience with it. Out here in the west it is Alder which looks somwhat similar to pine but is a bit harder (more durable) and around here the very top end homes have alder cabnetry (Knotty) which I think is crazy and would never use but it is popular and no sap leaks.
Drew
-- Drew, Pleasant Grove, Utah
Dorje
#6 posted 07-24-2007 09:46 PM
Drew has a good idea – Alder is a really good alternative. Plentiful around these parts…what about in Iowa?
phonewired
#7 posted 07-24-2007 10:29 PM
I just emaied my lumber supplier to find out about alder. It’s not on his list but I think the delivery driver had mentioned it several months ago. I can get red oak cheaper than I can get pine here. I’m going to do some quilt racks and some cabinets in oak because of the price and I like the looks. Pine is big in the main primitives dealers store that we sell to. Onward and upward! Thanks, Noel.
dennis mitchell
3994 posts in 4487 days
#8 posted 07-25-2007 03:55 PM
Give Alder a try. It is perfect for what you are doing. Maybe get a new supplier too. Alder is light and cheap.
phonewired
#9 posted 07-27-2007 12:41 AM
I can get Alder for maybe $2.00 per sq. foot delivered to my business. Should take 1 week. I’ll give it a try the next time I order. Thanks for the help guys and thanks Bill for the comments.Noel.
phonewired
#10 posted 08-14-2007 06:00 PM
Today I will have 3 types of wood delivered. Basswood, Alder and Poplar. I will be going to painted cabinets and shelves for awhile and see which type works best for me. Thanks for all the info and help, Noel.
Dorje
#11 posted 08-17-2007 05:46 AM
Best of luck trying those different woods – be sure to let us know which you prefer and why!
View scott shangraw's profile
scott shangraw
513 posts in 4242 days
#12 posted 08-17-2007 05:53 AM
I also would recomend alder as a good cost alternative to pine.Are you using kiln dried pine if so the place drying is not doing it at enough heat the sap should set up and be hard if they are taking it up over 130 degrees for any decent amount of time.
Good luck
-- Scott NM,http://www.shangrilawoodworks.com
18616 posts in 4333 days
#13 posted 08-17-2007 01:00 PM
I was watching a reno. show the other day that talked about alternative to pine (which takes 30 years to grow).. the alternative .. aspen? alder? ( i wasn’t quite paying attention at the time) only takes 15 years so is a better enviro. choice.
-- ~ Debbie, Canada (https://www.facebook.com/DebbiePribele, Young Living Wellness )
View rentman's profile
rentman
230 posts in 4267 days
#14 posted 08-17-2007 05:26 PM
I use a lot of pine and I have found epoxy to work really well,just put it on the knots( the 1 min stuff)let it dry, scrape it with a card scraper and roll on.I have never had a problem.Hope this helps.
-- Phil, Chattanooga,TN
View TreeBones's profile
TreeBones
1827 posts in 4196 days
#15 posted 08-18-2007 01:24 AM
Speaking of pine, I just milled a Canary Pine last week and the sap came out of it like an oil well (has major red grain stripes). I considered bottling it up. It is a rare occasion for me to wear gloves all day but this is one tree that needed it. I am still cleaning pitch patches. I cut mostly Ponderosa Pine along with several other species of pine out here and you will find pitch pockets where it will really flow out. When kiln drying, pine is usually heated up to 165 degrees at the end of the drying process. This is called “Pitch Set”. It hardens the pitch to stabilize it and it will sand much easer. There is a lot of air dried lumber available that is inexpensive but does not have the “Pitch Set”. Most of the air dried pine is labeled so you can look for that to help pick out your wood. Speaking of Alder, in Oregon it is the weed tree that loggers have a hard time getting rid of. It mostly goes to pallet stock until recently it started shipping out east for cabinet makers….
Hmmm.
-- Ron, Twain Harte, Ca. Portable on site Sawmill Service http://westcoastlands.net/Sawmill.html http://westcoastlands.net/SawBucks2/phpBB3 http://www.portablesawmill.info
