Pocket Screws or Butt Joints
« back to Joinery forum
Forum topic by EdsCustomWoodCrafts posted 01-08-2015 07:53 PM 938 views 0 times favorited 3 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
868 posts in 1583 days
01-08-2015 07:53 PM
Hi All,
And happy new year to all LJ’s…
I’m starting research on a new project.. I’ve got some 2×4 left and I’m going to be building either a single person chair or a 2 person bench and I’m wondering if I use 1 1/4 pocket screws will it be strong to enough to hold the weight… Or should I just do butt joints and sink 3” screws into them…
Thanks as always.
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
3 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2609 days
#1 posted 01-08-2015 08:40 PM
I think the pocket screws will work better since it screws into edge/face grain, and your other option is dependent on the screw going into end-grain, which is not as strong. Do you have some sketches? There may be stronger and/or more traditional joinery techniques that some people here with chair-building experience (not me) can comment on.
View txn's profile
txn
145 posts in 1699 days
#2 posted 01-08-2015 08:55 PM
1 1/4 pokcket screws are not long enough to work on 2×4 material you need 2 1/2in pocket hole screws for that but the kreg and some glue would be stronger than butt joint screwed from the outside
View greg48's profile
greg48
610 posts in 2997 days
#3 posted 01-08-2015 08:57 PM
At this point already?
The short answer is yes…...and no. If your only concern was weight, then either method is probably adequate, but if this is becoming something a person sits on, then you must start considering safety after all, we are no longer talking of breaking things but people. Incorporate the advice given in your shop bench build from LJ’er “handsawgeek” (ed) by considering the application of additional support from applied gussets or incorporating the support into the leg/seat design. Maybe you’re looking into a new joinery technique like through (or stopped) dados, screwed and glued. The options are many, don’t limit yourself with the two that you have already done.
Good Luck
-- Greg, No. Cal. - "Gaudete in Domino Semper"
