Gluing & Assembling 1/4" plywood project
Forum topic by Jim Crockett (USN Retired) posted 03-13-2009 04:25 AM 1142 views 0 times favorited 2 replies Add to Favorites Watch
View Jim Crockett (USN Retired)'s profile
852 posts in 3603 days
03-13-2009 04:25 AM
Any tips for gluing and assembling small projects made of 1/4” or 1/8” plywood? The couple of times I have tried this turned into nightmares – unable to keep the parts square and aligned. I figure that rabbeted corner joints would be superior to butt joints. Wonder how some of the new “wood” CA glues would work as the only glue? Clamping guides such as those Rockler sells would be nice but most projects I’m thinking of would be too small to use them – and they are darned expensive for a couple of small pieces of plastic!
JimC
-- A veteran is someone who, at one point in his/her life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including his/her life".
2 replies so far
View Gary's profile
Gary
9262 posts in 3302 days
#1 posted 03-13-2009 05:11 AM
http://www.leevalley.com/wood/page.aspx?c=2&p=31162&cat=1,43838
You can try this link for one of the best clamping tools I have ever used. Size of the wood doesn’t make any difference. I don’t know what you are gluing so, it may be too big as well….
View johnpoolesc's profile
johnpoolesc
246 posts in 3230 days
#2 posted 03-14-2009 10:35 PM
i perfer titebond 3, if possible put a thin coat on both parts, rub them together to produce heat at the joint.. almost shelf clamping.. then use that high end clamping tool called blue tape.. for picture frames, i never have enough corner clamps… painters tape works.. pretty good on band saw boxes as well where the shapes deny clamping with traditional clamps
-- It's not a sickness, i can stop buying tools anytime.
