Wood is Splitting, Help!
Forum topic by Primitiques posted 259 days ago 254 views 0 times favorited 4 replies Add to Favorites Watch
View Primitiques's profile
Primitiques
24 posts in 313 days
259 days ago
Hello all, I make furniture from Eastern White Pine (standard grade). Occasionally, my it may split on the sides when clamped and glued. I have began to tongue and groove the backs, which seems to be working, but how can I keep the sides from splitting, since they have to be clued together? Recently, I have been putting glue at the top and bottom of the pieces, basically rubbing glue on the top and bottom for about inches or so, hoping this will keep any splits from actually starting. Should I seal the intire piece once it is done, then paint it? I use milk-paint, then wax it with a stained beeswax I make, but I may have to seal it before I paint it, then paint it, and then wax it. I need help!!!!! I know predrilling the holes has helped stopped splits from occuring at the screw points, but now I need to stop splits on the ends. I do keep my wood in a basement area, which is pretty dry. Should I put some dehumidifiers down there maybe, or what?
Help,
Bill
View DaleM's profile
DaleM
416 posts in 281 days
259 days ago
Could you post a picture of the splits you are talking about? I work with a lot of pine, both Southern yellow and Eastern white and I know it can split and chip out easily, being fairly soft between the grain, but I’m not sure exactly what you are talking about. I’ve edge glued plenty of pieces as well as gluing many mortise and tenon joints and haven’t had too much of a problem. I just can’t picture exactly what is happening from your description.
-- Dale Manning, Carthage, NY
View Julian's profile
Julian
698 posts in 422 days
259 days ago
Yes, pictures would help us out.
Are you talking about large glued up panels? If so, you should try and break up the piece into smaller panels, so there won’t be as much wood movement.
-- Julian, Park Forest, IL
Primitiques
258 days ago
yes, it is mostly when I have a bunch of wood glued up on the back of pieces, primarily 1 X 12’s..recently i have been tongue and grooving the back. But occasionally, the sides will split since they are glued up. Do you think it would help to smother the sides with titebond glue, just cover it alll up, since we milk-paint over it anyway. I think if it is all glued up, it may never crack or split. I may get a dehumidifier too, to make sure it is around 8% dried. any pointers anyone????
View johnpoolesc's profile
johnpoolesc
250 posts in 257 days
257 days ago
your painting your wood.. just make sure you paint all the wood.. backs, bottoms, etc.. i would use sanding sealer, primer, paint then wax.. or poly..
wood splits because it is not drying evenly… if you plane or sand just one side, it will cup, if it can’t cup it will split..
-- It's not a sickness, i can stop buying tools anytime.
